i try to setup dvr with TSS 400 MKII…
The device is not discovered in the webgui
the log shows “Found device”
how can get the device working?
my Plex Tuner Service.log :
Nov 17, 2017 17:06:40.759 [0x7f8d05143700] INFO - Plex Tuner Service v1.0.0.0 - unknown PC unknown - build:
Nov 17, 2017 17:06:40.759 [0x7f8d05143700] INFO - Linux version: 4.4.0-98-generic (#121-Ubuntu SMP Tue Oct 10 14:24:03 UTC 2017), language: de-DE
Nov 17, 2017 17:06:40.760 [0x7f8d05143700] INFO - Processor Intel(R) Xeon(R) CPU W3670 @ 3.20GHz
Nov 17, 2017 17:06:40.760 [0x7f8d05143700] INFO - /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.9.7.4460-a39b25852 32600 /waitmutex
Nov 17, 2017 17:06:40.758 [0x7f8d0a5be780] INFO - * broker_t::start...
Nov 17, 2017 17:06:40.764 [0x7f8d0a5be780] INFO - * device_manager_t::init.
Nov 17, 2017 17:06:40.764 [0x7f8d0a5be780] INFO - * device_manager_t::init. Initialize provider manager
Nov 17, 2017 17:06:40.764 [0x7f8d0a5be780] INFO - * device_manager_t::init. Initialize all device auxes
Nov 17, 2017 17:06:40.764 [0x7f8d0a5be780] INFO - * dvb_device_factory_t::get_aux_list
Nov 17, 2017 17:06:40.765 [0x7f8d0a5be780] INFO - * tvbutler_aux_t::init
Nov 17, 2017 17:06:40.765 [0x7f8d0a5be780] INFO - * web_server_t::start. Starting web server on port 32600
Nov 17, 2017 17:06:48.437 [0x7f8cfdffb700] INFO - * web_service_t::process_device_discovery
Nov 17, 2017 17:06:48.437 [0x7f8cfdffb700] INFO - * device_reactor_t::get_device_list ()
Nov 17, 2017 17:06:48.437 [0x7f8cfdffb700] INFO - * dvb_device_factory_t::get_device_list ()
Nov 17, 2017 17:06:50.465 [0x7f8cfdffb700] INFO - * SAT2IP - server discovered: 192.168.1.103
Nov 17, 2017 17:06:50.465 [0x7f8cfdffb700] INFO - * SAT2IP - description XML: http://192.168.1.103:80/rootDescr
Nov 17, 2017 17:06:50.471 [0x7f8cfdffb700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#0#uuid:00000000-0000-1000-a2c0-00059e979ebb, Name Triax SatIP Converter (192.168.1.103) - 0, Standards 4
Nov 17, 2017 17:06:50.471 [0x7f8cfdffb700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#1#uuid:00000000-0000-1000-a2c0-00059e979ebb, Name Triax SatIP Converter (192.168.1.103) - 1, Standards 4
Nov 17, 2017 17:06:50.471 [0x7f8cfdffb700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#2#uuid:00000000-0000-1000-a2c0-00059e979ebb, Name Triax SatIP Converter (192.168.1.103) - 2, Standards 4
Nov 17, 2017 17:06:50.471 [0x7f8cfdffb700] INFO - * dvb_device_factory_t::get_device_list. Id dvb#sat2ip#3#uuid:00000000-0000-1000-a2c0-00059e979ebb, Name Triax SatIP Converter (192.168.1.103) - 3, Standards 4
Nov 17, 2017 17:06:50.877 [0x7f8cfdffb700] INFO - * v4l::DeviceGetList_impl. getting v4l device list
Nov 17, 2017 17:06:50.879 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx >>
Nov 17, 2017 17:06:50.880 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:3
Nov 17, 2017 17:06:50.880 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:2
Nov 17, 2017 17:06:50.880 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx. Found device 3725:6486
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx. Found device 3599:2
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx. Found device 3599:3
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * onetv_factory::DeviceGetListEx. Found device 7531:1
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * device_manager_t::get_device_list. Device Triax SatIP Converter (192.168.1.103) - 0, id dvb#sat2ip#0#uuid:00000000-0000-1000-a2c0-00059e979ebb, tuners 1, state 0, standards 4
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * device_manager_t::get_device_list. Device Triax SatIP Converter (192.168.1.103) - 1, id dvb#sat2ip#1#uuid:00000000-0000-1000-a2c0-00059e979ebb, tuners 1, state 0, standards 4
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * device_manager_t::get_device_list. Device Triax SatIP Converter (192.168.1.103) - 2, id dvb#sat2ip#2#uuid:00000000-0000-1000-a2c0-00059e979ebb, tuners 1, state 0, standards 4
Nov 17, 2017 17:06:50.881 [0x7f8cfdffb700] INFO - * device_manager_t::get_device_list. Device Triax SatIP Converter (192.168.1.103) - 3, id dvb#sat2ip#3#uuid:00000000-0000-1000-a2c0-00059e979ebb, tuners 1, state 0, standards 4
