Here is another example. I set it to record 48 hours. It is 10:32pm my time so the recording should have ended 30 minutes ago. PLEX seems to be stuck saying the tuner is still recording.
When I check the folder where recording are supposed to be saved there is a 186mb file in the .grab folder titled 48 Hours (1988) - S31E25 - The Last Ride Home that is only 2 minutes long.
Here is the Tuner Service log file if that could lead to any clues as to what is happening.
Thanks for any help.
Apr 28, 2018 20:40:10.803 [9076] INFO - Plex Tuner Service v1.0.0.0 - Microsoft PC x64 - build:
Apr 28, 2018 20:40:10.803 [9076] INFO - Windows version: 6.2 (Build 9200), language en-US
Apr 28, 2018 20:40:10.803 [9076] INFO - 4 3193 MHz processor(s): Architecture=0, Level=6, Revision=15363 Processor Identifier=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
Apr 28, 2018 20:40:10.803 [9076] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Tuner Service.exe” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private” “C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Shared” 1.12.3.4973-215c28d86 32600 /waitmutex
Apr 28, 2018 20:40:10.763 [2132] INFO - * broker_t::start…
Apr 28, 2018 20:40:11.187 [2132] INFO - * device_manager_t::init.
Apr 28, 2018 20:40:11.187 [2132] INFO - * device_manager_t::init. Initialize provider manager
Apr 28, 2018 20:40:11.187 [2132] INFO - * device_manager_t::init. Initialize all device auxes
Apr 28, 2018 20:40:11.187 [2132] INFO - * dvb_device_factory_t::get_aux_list
Apr 28, 2018 20:40:11.187 [2132] INFO - * bda_aux_t::init
Apr 28, 2018 20:40:11.255 [2132] INFO - * web_server_t::start. Starting web server on port 32600
Apr 28, 2018 20:40:14.785 [3260] INFO - * web_service_t::process_device_discovery
Apr 28, 2018 20:40:14.785 [3260] INFO - * device_reactor_t::get_device_list ()
Apr 28, 2018 20:40:14.785 [3260] INFO - * dvb_device_factory_t::get_device_list ()
Apr 28, 2018 20:40:16.669 [1660] INFO - * web_service_t::process_start_channel (device dvb#hdhr#0#269843765, channel triplet://0:2643:3)
Apr 28, 2018 20:40:16.829 [3260] INFO - * SAT2IP - discover_satip_servers(): no servers found
Apr 28, 2018 20:40:17.197 [1660] INFO - * device_manager_t::add_streamer. Channel triplet://0:2643:3, device dvb#hdhr#0#269843765, streamer id 34d10475-6c8f-414a-9dbf-9e6f78845169
Apr 28, 2018 20:40:17.197 [1660] INFO - * device_reactor_t::create_device dvb#hdhr#0#269843765
Apr 28, 2018 20:40:17.199 [1660] INFO - * device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:2643:3 on device device dvb#hdhr#0#269843765.
Apr 28, 2018 20:40:17.201 [1660] INFO - * transponder_streamer::start_idle_timer
Apr 28, 2018 20:40:17.201 [1660] INFO - * tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 2643, sid 3
Apr 28, 2018 20:40:17.217 [12076] INFO - * streamer_container_t::control_thread. Added streamer 34d10475-6c8f-414a-9dbf-9e6f78845169
Apr 28, 2018 20:40:17.217 [12076] INFO - * streamer_container_t::control_thread. First streamer was added. Start program streamer
Apr 28, 2018 20:40:17.217 [12076] INFO - * dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:2643:3
Apr 28, 2018 20:40:17.217 [12076] INFO - * transponder_streamer::start_channel. Start request for channel triplet://0:2643:3
Apr 28, 2018 20:40:17.219 [12076] INFO - * transponder_streamer::stop_idle_timer
Apr 28, 2018 20:40:17.263 [3260] INFO - * dvb_device_factory_t::get_device_list. Id dvb#hdhr#0#269843765, Name HDHomeRun 10157D35 (192.168.2.58) - 0, Standards 24
Apr 28, 2018 20:40:17.263 [3260] INFO - * dvb_device_factory_t::get_device_list. Id dvb#hdhr#1#269843765, Name HDHomeRun 10157D35 (192.168.2.58) - 1, Standards 24
Apr 28, 2018 20:40:17.263 [3260] INFO - * dvb_device_factory_t::get_device_list. Id dvb#hdhr#0#270612664, Name HDHomeRun 102138B8 (192.168.2.59) - 0, Standards 24
Apr 28, 2018 20:40:17.297 [12072] INFO - * hdhr_tuner_t::StartDevice. Starting device 269843765, frontend 0
Apr 28, 2018 20:40:17.299 [12072] INFO - * CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 11, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Apr 28, 2018 20:40:17.299 [12072] INFO - * HDHR get_tuning_string: 8vsb:201028615
Apr 28, 2018 20:40:17.305 [12080] INFO - * DeviceGetListEx_impl: Filter [Silicondust HDHomeRun Tuner 10157D35-0]
Apr 28, 2018 20:40:17.305 [12080] DEBUG - * BDA: DeviceGetListEx_impl. Skipped Silicondust virtual BDA driver
Apr 28, 2018 20:40:17.305 [12080] INFO - * DeviceGetListEx_impl: Filter [Silicondust HDHomeRun Tuner 10157D35-1]
Apr 28, 2018 20:40:17.305 [12080] INFO - * DeviceGetListEx_impl: Filter [Silicondust HDHomeRun Tuner 102138B8-0]
Apr 28, 2018 20:40:17.305 [12080] INFO - * DeviceGetListEx_impl: pDL->Count:0
Apr 28, 2018 20:40:17.307 [3260] DEBUG - * file_tuner::get_stream_file. File C:\Program Files (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
Apr 28, 2018 20:40:17.311 [12072] WARN - [E] hdhr_tuner_t::SetTuner. hdhomerun_device_set_tuner_channel returned an error 0
Apr 28, 2018 20:40:17.311 [12072] WARN - [E] CTVSStreamSource::IntTuneTransponder. tuner_->SetTuner returned an error
Apr 28, 2018 20:40:17.311 [12076] WARN - [E] tune_transponder. Unable to tune transponder
Apr 28, 2018 20:40:17.311 [12076] WARN - [E] transponder_streamer::start_channel. Tuning stransponder for channel triplet://0:2643:3 failed
Apr 28, 2018 20:40:17.311 [12076] INFO - * transponder_streamer::start_idle_timer
Apr 28, 2018 20:40:17.313 [12076] WARN - [E] streamer_container_t::control_thread. program_streamer_->start() failed for streamer 34d10475-6c8f-414a-9dbf-9e6f78845169
Apr 28, 2018 20:40:17.313 [1660] WARN - [E] web_service_t::process_start_channel. device_manager_->add_streamer returned error
Apr 28, 2018 20:40:17.323 [3260] INFO - * device_manager_t::get_device_list. Device HDHomeRun 10157D35 (192.168.2.58) - 0, id dvb#hdhr#0#269843765, tuners 1, state 1, standards 24
Apr 28, 2018 20:40:17.323 [3260] INFO - * device_manager_t::get_device_list. Device HDHomeRun 10157D35 (192.168.2.58) - 1, id dvb#hdhr#1#269843765, tuners 1, state 0, standards 24
Apr 28, 2018 20:40:17.323 [3260] INFO - * device_manager_t::get_device_list. Device HDHomeRun 102138B8 (192.168.2.59) - 0, id dvb#hdhr#0#270612664, tuners 1, state 0, standards 24
Apr 28, 2018 20:40:17.477 [11268] INFO - * web_service_t::process_device_status
Apr 28, 2018 20:40:17.921 [1660] INFO - * web_service_t::process_get_scanners
Apr 28, 2018 20:40:18.659 [1660] INFO - * web_service_t::process_device_status
Apr 28, 2018 20:40:19.093 [11268] INFO - * web_service_t::process_get_scanners
Apr 28, 2018 20:40:19.535 [1660] INFO - * web_service_t::process_device_status
Apr 28, 2018 20:40:19.989 [1660] INFO - * web_service_t::process_get_scanners
Apr 28, 2018 20:40:20.464 [11268] INFO - * web_service_t::process_device_status
Apr 28, 2018 20:40:20.888 [11268] INFO - * web_service_t::process_get_scanners
Apr 28, 2018 20:40:21.314 [8916] INFO - * device_manager_t::idle_timer_func. Stream container for channel triplet://0:2643:3 on device dvb#hdhr#0#269843765 is idle. Deleting it.
Apr 28, 2018 20:40:27.364 [12068] INFO - * Stopping graph
Apr 28, 2018 20:40:31.416 [8916] INFO - * device_manager_t::idle_timer_func. Device dvb#hdhr#0#269843765 is idle. Unloading it.
Apr 28, 2018 20:40:31.416 [8916] INFO - * transponder_streamer::stop_idle_timer
Apr 28, 2018 20:40:31.416 [8916] INFO - * CTVSStreamSource::Term. Waiting for streaming thread to stop
Apr 28, 2018 20:40:31.461 [8916] INFO - * CTVSStreamSource::Term. Streaming is stopped
Apr 28, 2018 20:40:31.461 [8916] INFO - * CTVSStreamSource::Term. Stream source is stopped
Apr 28, 2018 20:40:32.464 [12068] INFO - * transponder_streamer::idle_thread_func finished
Apr 28, 2018 20:43:00.619 [11268] INFO - * web_service_t::process_start_channel (device dvb#hdhr#0#269843765, channel triplet://0:2643:3)
Apr 28, 2018 20:43:01.040 [11268] INFO - * device_manager_t::add_streamer. Channel triplet://0:2643:3, device dvb#hdhr#0#269843765, streamer id 48ff1759-66fc-41d3-b7dc-3731877d7e90
Apr 28, 2018 20:43:01.040 [11268] INFO - * device_reactor_t::create_device dvb#hdhr#0#269843765
Apr 28, 2018 20:43:01.040 [11268] INFO - * device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:2643:3 on device device dvb#hdhr#0#269843765.
Apr 28, 2018 20:43:01.041 [11268] INFO - * transponder_streamer::start_idle_timer
Apr 28, 2018 20:43:01.041 [11268] INFO - * tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 2643, sid 3
Apr 28, 2018 20:43:01.042 [7384] INFO - * streamer_container_t::control_thread. Added streamer 48ff1759-66fc-41d3-b7dc-3731877d7e90
Apr 28, 2018 20:43:01.042 [7384] INFO - * streamer_container_t::control_thread. First streamer was added. Start program streamer
Apr 28, 2018 20:43:01.042 [7384] INFO - * dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:2643:3
Apr 28, 2018 20:43:01.042 [7384] INFO - * transponder_streamer::start_channel. Start request for channel triplet://0:2643:3
Apr 28, 2018 20:43:01.042 [7384] INFO - * transponder_streamer::stop_idle_timer
Apr 28, 2018 20:43:01.093 [8608] INFO - * hdhr_tuner_t::StartDevice. Starting device 269843765, frontend 0
Apr 28, 2018 20:43:01.094 [8608] INFO - * CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 11, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Apr 28, 2018 20:43:01.094 [8608] INFO - * HDHR get_tuning_string: 8vsb:201028615
Apr 28, 2018 20:43:01.106 [8608] WARN - [E] hdhr_tuner_t::SetTuner. hdhomerun_device_set_tuner_channel returned an error 0
Apr 28, 2018 20:43:01.106 [8608] WARN - [E] CTVSStreamSource::IntTuneTransponder. tuner_->SetTuner returned an error
Apr 28, 2018 20:43:01.106 [7384] WARN - [E] tune_transponder. Unable to tune transponder
Apr 28, 2018 20:43:01.106 [7384] WARN - [E] transponder_streamer::start_channel. Tuning stransponder for channel triplet://0:2643:3 failed
Apr 28, 2018 20:43:01.106 [7384] INFO - * transponder_streamer::start_idle_timer
Apr 28, 2018 20:43:01.106 [7384] WARN - [E] streamer_container_t::control_thread. program_streamer_->start() failed for streamer 48ff1759-66fc-41d3-b7dc-3731877d7e90
Apr 28, 2018 20:43:01.106 [11268] WARN - [E] web_service_t::process_start_channel. device_manager_->add_streamer returned error
Apr 28, 2018 20:43:02.638 [8916] INFO - * device_manager_t::idle_timer_func. Stream container for channel triplet://0:2643:3 on device dvb#hdhr#0#269843765 is idle. Deleting it.
Apr 28, 2018 20:43:11.051 [11984] INFO - * Stopping graph
Apr 28, 2018 20:43:12.658 [8916] INFO - * device_manager_t::idle_timer_func. Device dvb#hdhr#0#269843765 is idle. Unloading it.
Apr 28, 2018 20:43:12.658 [8916] INFO - * transponder_streamer::stop_idle_timer
Apr 28, 2018 20:43:12.658 [8916] INFO - * CTVSStreamSource::Term. Waiting for streaming thread to stop
Apr 28, 2018 20:43:12.706 [8916] INFO - * CTVSStreamSource::Term. Streaming is stopped
Apr 28, 2018 20:43:12.706 [8916] INFO - * CTVSStreamSource::Term. Stream source is stopped
Apr 28, 2018 20:43:13.072 [11984] INFO - * transponder_streamer::idle_thread_func finished
Apr 28, 2018 20:58:01.566 [1660] INFO - * web_service_t::process_start_channel (device dvb#hdhr#0#269843765, channel triplet://0:2643:3)
Apr 28, 2018 20:58:02.010 [1660] INFO - * device_manager_t::add_streamer. Channel triplet://0:2643:3, device dvb#hdhr#0#269843765, streamer id a6f76bf8-0eb5-4974-a5e9-eb0537a802fb
Apr 28, 2018 20:58:02.010 [1660] INFO - * device_reactor_t::create_device dvb#hdhr#0#269843765
Apr 28, 2018 20:58:02.010 [1660] INFO - * device_manager_t::add_streamer. Adding new streamer container for channel triplet://0:2643:3 on device device dvb#hdhr#0#269843765.
Apr 28, 2018 20:58:02.011 [1660] INFO - * transponder_streamer::start_idle_timer
Apr 28, 2018 20:58:02.011 [1660] INFO - * tvs_program_streamer::tvs_program_streamer. Select program for nid 0, tid 2643, sid 3
Apr 28, 2018 20:58:02.011 [9628] INFO - * streamer_container_t::control_thread. Added streamer a6f76bf8-0eb5-4974-a5e9-eb0537a802fb
Apr 28, 2018 20:58:02.011 [9628] INFO - * streamer_container_t::control_thread. First streamer was added. Start program streamer
Apr 28, 2018 20:58:02.011 [9628] INFO - * dvb_program_streamer_t::start. Starting program streamer for channel triplet://0:2643:3
Apr 28, 2018 20:58:02.011 [9628] INFO - * transponder_streamer::start_channel. Start request for channel triplet://0:2643:3
Apr 28, 2018 20:58:02.012 [9628] INFO - * transponder_streamer::stop_idle_timer
Apr 28, 2018 20:58:02.061 [4572] INFO - * hdhr_tuner_t::StartDevice. Starting device 269843765, frontend 0
Apr 28, 2018 20:58:02.061 [4572] INFO - * CTVSStreamSource::TuneTransponder. Transponder tuning request: diseqc 0, freq 11, modulation 0, polarization 0, symbol rate 0, LOF 0, LNB selection signal 0, FEC 0
Apr 28, 2018 20:58:02.061 [4572] INFO - * HDHR get_tuning_string: 8vsb:201028615
Apr 28, 2018 20:58:02.830 [4572] INFO - * hdhr_tuner_t::SetTuner. wait_for_lock status: 1, 81
Apr 28, 2018 20:58:02.957 [9628] INFO - * transponder_streamer::tune_transponder_impl. Signal stats: 100, 81, 1
Apr 28, 2018 20:58:02.957 [12148] INFO - * tvs_program_streamer::tuning_thread. Starting tuning thread for program triplet://0:2643:3
Apr 28, 2018 20:58:02.957 [12148] INFO - * tvs_program_streamer::SetPATScanState. Waiting for PAT…
Apr 28, 2018 20:58:02.964 [9496] INFO - * http_streamer_t::send_thread_func: adding http client
Apr 28, 2018 20:58:03.007 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:2643:3
Apr 28, 2018 20:58:03.007 [4572] INFO - * HDHR add_pid. Adding pid 0
Apr 28, 2018 20:58:03.009 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:2643:3
Apr 28, 2018 20:58:03.009 [4572] INFO - * HDHR add_pid. Adding pid 1
Apr 28, 2018 20:58:03.010 [4572] DEBUG - * required sid 3
Apr 28, 2018 20:58:03.010 [4572] DEBUG - * services (4): 3,
Apr 28, 2018 20:58:03.010 [4572] DEBUG - * pmt pid found: 48
Apr 28, 2018 20:58:03.059 [12148] INFO - * tvs_program_streamer::tuning_thread. Waiting for PMT…
Apr 28, 2018 20:58:03.060 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 48, client triplet://0:2643:3
Apr 28, 2018 20:58:03.060 [4572] INFO - * HDHR add_pid. Adding pid 48
Apr 28, 2018 20:58:03.527 [12148] INFO - * tvs_program_streamer::tuning_thread. PAT and PMT found. Checking CA descriptors
Apr 28, 2018 20:58:03.577 [12148] INFO - * tvs_program_streamer::tuning_thread. Start streaming
Apr 28, 2018 20:58:03.595 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 49, client triplet://0:2643:3
Apr 28, 2018 20:58:03.595 [4572] INFO - * HDHR add_pid. Adding pid 49
Apr 28, 2018 20:58:03.595 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 52, client triplet://0:2643:3
Apr 28, 2018 20:58:03.595 [4572] INFO - * HDHR add_pid. Adding pid 52
Apr 28, 2018 20:58:03.596 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 53, client triplet://0:2643:3
Apr 28, 2018 20:58:03.596 [4572] INFO - * HDHR add_pid. Adding pid 53
Apr 28, 2018 20:58:03.597 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 49, client triplet://0:2643:3
Apr 28, 2018 20:58:03.597 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 0, client triplet://0:2643:3
Apr 28, 2018 20:58:03.597 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 1, client triplet://0:2643:3
Apr 28, 2018 20:58:03.597 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 16, client triplet://0:2643:3
Apr 28, 2018 20:58:03.597 [4572] INFO - * HDHR add_pid. Adding pid 16
Apr 28, 2018 20:58:03.598 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 17, client triplet://0:2643:3
Apr 28, 2018 20:58:03.598 [4572] INFO - * HDHR add_pid. Adding pid 17
Apr 28, 2018 20:58:03.599 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 18, client triplet://0:2643:3
Apr 28, 2018 20:58:03.599 [4572] INFO - * HDHR add_pid. Adding pid 18
Apr 28, 2018 20:58:03.599 [4572] INFO - * CTVSStreamSource::AddPID. Requesting PID 8191, client triplet://0:2643:3
Apr 28, 2018 20:58:03.650 [12148] INFO - * tvs_program_streamer::tuning_thread. Finished tuning thread for program triplet://0:2643:3
Apr 28, 2018 20:58:03.940 [4572] INFO - * CTSStreamWaiter::GetPidToCheck. PID to check 49
Apr 28, 2018 20:58:03.940 [4572] INFO - * CTSStreamWaiter::GetVideoPid. Video PID 49
Apr 28, 2018 20:58:03.951 [4572] INFO - * CTSStreamWaiter::ProcessStream. Found first not encrypted packet. Start streaming
Nothing after 8:58PM when the recording started.
