DVR: watch from start caught in an endless loop (Android TV)
I am experiencing a strange problem when trying to start a (still) active recording from start on my Bravia TV (version 8.14.1.23548). The recording keeps playing the first 1-2 seconds and then jumps back to repeat the same again and again. This does not happen on any other player so I assume it’s a problem of the Android TV player. Once the recording has finished, it can be played without any problem.
Looking at the log file one can spot many Broken pipe entries at the time I tried to watch the recording from start.
Plex Media Server Logs_2021-03-22_11-33-13.zip (4.2 MB)
Mar 22, 2021 11:32:49.331 [0x700001296000] DEBUG - Failed to stream media, client probably disconnected after 1261568 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:49.709 [0x700001213000] DEBUG - Failed to stream media, client probably disconnected after 720896 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:52.825 [0x700001213000] DEBUG - Failed to stream media, client probably disconnected after 573440 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:52.832 [0x700001296000] DEBUG - Failed to stream media, client probably disconnected after 999424 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:56.709 [0x700001213000] DEBUG - Failed to stream media, client probably disconnected after 1294336 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:58.970 [0x700001296000] DEBUG - Failed to stream media, client probably disconnected after 327680 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:59.734 [0x700001213000] DEBUG - Failed to stream media, client probably disconnected after 983040 bytes: 32 - Broken pipe
Mar 22, 2021 11:32:59.744 [0x700001296000] DEBUG - Failed to stream media, client probably disconnected after 245760 bytes: 32 - Broken pipe
Mar 22, 2021 11:33:04.061 [0x700001296000] DEBUG - Failed to stream media, client probably disconnected after 540672 bytes: 32 - Broken pipe
Mar 22, 2021 11:33:05.200 [0x700001296000] DEBUG - Failed to stream media, client probably disconnected after 1310720 bytes: 32 - Broken pipe
Just realizing that there is also another post reporting the same issue: DVR - Watch From Start - Why doesn't it work on Android TV clients?
Happening to me on Google TV as well
I honestly think the more posts the better. DVR i supposed to be a fundamental function of Plex, but why are we having to deal with this not working for so long?
Here to report I too am having the SAME issue. NVIDIA Shield is where the issues present.
I have the same issue on my Nvidia Shield. Recorded TV on Plex needs some major work.
