EAC3 codec error still an issue
Hi
Still encountering the EAC3 codec issue using latest linuxserver docker build.
Jobs: Exec of /config/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-1591-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder failed. (13)
Fix here works - Any video with EAC3 audio fails to play - #2 by mikefallen
Just flagging that I encountered this issue in case it was supposed to be fix.
As an additional step after deleting at letting plex recreate the codec directory I also increased fs.inotify.max_user_watches in case that was a releated issue.
There are all sort of problems with this codec, one being Plex not detecting Intros. I wasn’t lucky enough to get a solution for my problem, but I hope someone can help you with yours.
