I can't play media with EAC3 audio
Server Version#: 1.41.4.9463
Player Version#: Any browser or Phone app
Hi. I can’t play any media with EAC3 audio. I’ve tried everything I found online, from renaming the codecs folder to “codecs.old” forcing a redownload of all the codecs, no luck. I also tried downloading and replacing the encoders and decoders for EAC3 manually in the folders, but still no luck. It seems that the codec is in the folder but cannot use it or something like that, I am not sure why it’s doing this. I don’t have any problem with any other media beside that.
Here are the error logs when I try to start any media with EAC3:
Mar 11, 2025 01:32:35.280 [140275155315512] Debug — [Req#4523/Transcode] Starting a transcode session 28a2da3rwusj8p13zlkb8zv3 at offset -1.0 (state=3)
Mar 11, 2025 01:32:35.282 [140275155315512] Info — [Req#4523/Transcode] CodecManager: obtaining EAE
Mar 11, 2025 01:32:35.282 [140275155315512] Debug — [Req#4523/Transcode/HCl#a5] HTTP requesting GET https://plex.tv/api/codecs/easyaudioencoder?build=linux-x86_64-standard&deviceId=ff7f674a-b514-489b-af16-a1754fda511a&oldestPreviousVersion=1.41.3.9314-a0bfb8370&version=8f4ca5ead7783c54a4930420
Mar 11, 2025 01:32:35.520 [140275175664440] Debug — [HttpClient/HCl#a5] HTTP/1.1 (0.2s) 429 response from GET https://plex.tv/api/codecs/easyaudioencoder?build=linux-x86_64-standard&deviceId=ff7f674a-b514-489b-af16-a1754fda511a&oldestPreviousVersion=1.41.3.9314-a0bfb8370&version=8f4ca5ead7783c54a4930420
Mar 11, 2025 01:32:35.520 [140275168131896] Error — [Req#4523/Transcode] Codecs: Failed to download XML for codec ‘easyaudioencoder’
Mar 11, 2025 01:32:35.520 [140275155315512] Error — [Req#4523/Transcode] Error configuring transcoder: Decoder install failed: eac3_eae
Mar 11, 2025 01:32:35.520 [140275155315512] Debug — [Req#4523/Transcode] Streaming Resource: Terminating session 0x7f9456b31ad8:11ocoijgn3pk1tppwtn8taau which is using 69283kbps of WAN bandwidth. Used is now 0kbps
Mar 11, 2025 01:32:35.521 [140275155315512] Debug — [Req#4523/Transcode] Streaming Resource: Terminated session 0x7f9456b31ad8:11ocoijgn3pk1tppwtn8taau with reason Conversion failed. A required codec could not be found or failed to install.
I finaly got it to work after installing Dolby AC-3/AC-4 Installer from Download Dolby AC-3/AC-4 Installer - MajorGeeks
429 is the HTTP code for too many requests. That’s because your IP was trying too many times and you got temporarily blocked. Most likely what fixed it was it just trying again later.
I fixed it by transferring the “codecs” folder from an older backup of the server.
You are the MVP. That fixed it for me. Thanks :+1:
