EAC3 not working
After updating PMS recently, many of my EAC3 streams error out, saying the connection to PMS was lost. Below are the logs for the player.
Plex is running on Nvidia Shield TV, through an amp that supports EAC3 and AC3, and both were working fine before update.
Any thoughts?
11-23 20:52:08.957  i: [MediaDecisionEngine] Decision: CanPlay: true CanDirectPlay: false CanDirectStreamVideo: true CanDirectStreamAudio: true CanDirectPlaySubtitle: false CanTranscodeSubtitle: false Transcode Reason: Container (ac3) not supported
11-23 20:52:08.957  i: [video] Decision made, transcode: true
11-23 20:52:08.957  i: [TranscodeSession] Media choice updated
11-23 20:52:08.958  i: [VideoOverlay] Updating...
11-23 20:52:08.961  i: [video] Starting Playback for: The Tesla Recoil
11-23 20:52:08.961  i: [Exo1VideoPlayer] Using HlsRendererBuilder.
11-23 20:52:08.961  i: [video] User maximum h264 profile determined: 51
11-23 20:52:08.961  i: [video] Device recommended h264 profile determined: 51
11-23 20:52:08.961  i: Fetching [method:GET] https://192.168.1.130:32400/:/timeline?containerKey=%2FplayQueues%2F405&duration=11059200&guid=com.plexapp.agents.thetvdb%3A%2F%2F80379%2F11%2F8%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F2764&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=4523&ratingKey=2764&state=buffering&time=0&token=...7NNH&X-Plex-Client-Identifier=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Token=...7NNH
11-23 20:52:08.965  i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
11-23 20:52:08.966  i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
11-23 20:52:08.966  i: [BufferHelper] Segment count: 3276
11-23 20:52:08.968  i: [RefreshRateBehaviour] Checking refresh rate
11-23 20:52:08.969  i: [RefreshRateBehaviour] Refresh rates available:
11-23 20:52:08.970  i: [RefreshRateBehaviour] Current refresh rate: 59.94006
11-23 20:52:08.971  i: [RefreshRateBehaviour] Best refresh rate: 59.94006 (1920x1080)
11-23 20:52:08.978  i: [RefreshRateBehaviour] No refresh rate switch required
11-23 20:52:08.979  i: [DeviceCapabilitiesChangedBehaviour] Recording source codec (eac3) support: true (Passthrough: true)
11-23 20:52:09.063  i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
11-23 20:52:09.064  i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
11-23 20:52:09.064  i: [BufferHelper] Segment count: 3276
11-23 20:52:09.067  i: [ExoVideoPlayer] Renderers received
11-23 20:52:09.067  i: [ExoVideoPlayer] Seeking to 0ms
11-23 20:52:09.083  i: [Exo1VideoPlayer] Player state changed: 2, Restarting: true
11-23 20:52:10.697  i: [ThemeMusic] Fade out complete. Stopping media player.
11-23 20:52:14.003  e: [Exo1VideoPlayer] Player error detected
11-23 20:52:14.004  e: An exception occurred: com.google.android.exoplayer.j: com.google.android.exoplayer.f.z: Unexpected IllegalStateException: null
11-23 20:52:14.004  e: Stacktrace: com.google.android.exoplayer.j: com.google.android.exoplayer.f.z: Unexpected IllegalStateException: null
	at com.google.android.exoplayer.am.a(SourceFile:262)
	at com.google.android.exoplayer.am.d(SourceFile:148)
	at com.google.android.exoplayer.p.f(SourceFile:273)
	at com.google.android.exoplayer.p.handleMessage(SourceFile:203)
	at android.os.Handler.dispatchMessage(Handler.java:98)
	at android.os.Looper.loop(Looper.java:154)
	at android.os.HandlerThread.run(HandlerThread.java:61)
	at com.google.android.exoplayer.g.y.run(SourceFile:40)
Caused by: com.google.android.exoplayer.f.z: Unexpected IllegalStateException: null
	at com.google.android.exoplayer.f.x.run(SourceFile:235)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:428)
	at java.util.concurrent.FutureTask.run(FutureTask.java:237)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1133)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:607)
	at java.lang.Thread.run(Thread.java:761)
Caused by: java.lang.IllegalStateException
	at com.google.android.exoplayer.g.b.b(SourceFile:65)
	at com.google.android.exoplayer.g.u.g(SourceFile:228)
	at com.google.android.exoplayer.g.u.b(SourceFile:115)
	at com.google.android.exoplayer.g.a.b(SourceFile:154)
	at com.google.android.exoplayer.d.e.a.c(SourceFile:166)
	at com.google.android.exoplayer.d.e.a.a(SourceFile:95)
	at com.google.android.exoplayer.d.e.v.a(SourceFile:649)
	at com.google.android.exoplayer.d.e.t.a(SourceFile:226)
	at com.google.android.exoplayer.e.g.a(SourceFile:238)
	at com.google.android.exoplayer.e.t.h(SourceFile:116)
	at com.google.android.exoplayer.f.x.run(SourceFile:222)
	... 5 more
11-23 20:52:14.040  i: [video] Error detected before playback
11-23 20:52:14.043  i: [Exo1VideoPlayer] Player state changed: 1, Restarting: true
11-23 20:52:14.053  i: Fetching [method:GET] https://192.168.1.130:32400/:/timeline?bandwidth=21106&containerKey=%2FplayQueues%2F405&duration=11059200&guid=com.plexapp.agents.thetvdb%3A%2F%2F80379%2F11%2F8%3Flang%3Den&key=%2Flibrary%2Fmetadata%2F2764&location=lan&machineIdentifier=d8793166988cd8f6a74e18b775f871de3ebd28c5&playQueueItemID=4523&ratingKey=2764&state=stopped&time=0&token=...7NNH&X-Plex-Client-Identifier=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Token=...7NNH
11-23 20:52:14.301  i: [TranscodeSession] Stopping...
11-23 20:52:14.314  i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
11-23 20:52:14.314  i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
11-23 20:52:14.314  i: [BufferHelper] Segment count: 3276
11-23 20:52:14.315  i: [TranscodeSession] Notifying server that we've stopped
11-23 20:52:14.315  i: Fetching [method:GET] https://192.168.1.130:32400/video/:/transcode/universal/stop?autoAdjustQuality=1&hasMDE=1&location=lan&mediaBufferSize=209664&session=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Client-Identifier=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...7NNH
11-23 20:52:14.325  e: [Video Player] A recoverable error occurred while attempting to play: /library/metadata/2764.
11-23 20:52:14.325  e: [Video Player] Playback has stopped because the connection to the Plex Media Server has been lost. Please ensure the server is available and retry.
11-23 20:52:14.325  i: [Video Player] Showing retry playback dialog.
11-23 20:52:14.392  i: [UpdateRecommendationsService] Updating recommendations...
11-23 20:52:14.392  i: Fetching [method:GET] https://192.168.1.130:32400/hubs?X-Plex-Token=...7NNH
11-23 20:52:14.638  i: [pms] /192.168.1.154:54138 - GET /logging
11-23 20:52:14.682  i: [UpdateRecommendationsService] 0 recommendations made from hub 'home.continue'.
11-23 20:52:14.785  i: [UpdateRecommendationsService] Adding recommendation for item The Big Bang Theory - S11 E08 (URI=plex://d8793166988cd8f6a74e18b775f871de3ebd28c5/episode/%2Flibrary%2Fmetadata%2F2764%3FcheckFiles%3D1%26includeExtras%3D1%26includeRelated%3D1%26includeRelatedCount%3D0%26includeReviews%3D1)
11-23 20:52:14.866  i: [UpdateRecommendationsService] Adding recommendation for item Scandal (2012) - S07 E06 (URI=plex://d8793166988cd8f6a74e18b775f871de3ebd28c5/episode/%2Flibrary%2Fmetadata%2F2717%3FcheckFiles%3D1%26includeExtras%3D1%26includeRelated%3D1%26includeRelatedCount%3D0%26includeReviews%3D1)
11-23 20:52:14.925  i: [UpdateRecommendationsService] Adding recommendation for item The Deuce - S01 E01 (URI=plex://d8793166988cd8f6a74e18b775f871de3ebd28c5/episode/%2Flibrary%2Fmetadata%2F2216%3FcheckFiles%3D1%26includeExtras%3D1%26includeRelated%3D1%26includeRelatedCount%3D0%26includeReviews%3D1)
11-23 20:52:14.926  i: [UpdateRecommendationsService] 3 recommendations made from hub 'home.ondeck'.
11-23 20:52:14.951  i: [UpdateRecommendationsService] Finished making recommendations. Total=3.
11-23 20:52:17.155  i: [pms] /192.168.1.154:54139 - GET /logging
11-23 20:58:54.751  i: [UserAction] Click 'cancel' on retry playback dialog.
11-23 20:58:54.776  i: [TranscodeSession] Stopping...
11-23 20:58:54.787  i: [BufferHelper] Assumed Bitrate: 400000, Segment Count: 46875
11-23 20:58:54.787  i: [BufferHelper] Detected memory pressure, reducing segment count to fit available memory: 512
11-23 20:58:54.787  i: [BufferHelper] Segment count: 3276
11-23 20:58:54.787  i: [TranscodeSession] Notifying server that we've stopped
11-23 20:58:54.787  i: Fetching [method:GET] https://192.168.1.130:32400/video/:/transcode/universal/stop?autoAdjustQuality=1&hasMDE=1&location=lan&mediaBufferSize=209664&session=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Client-Identifier=8f64587ec8a41fd3-com-plexapp-android&X-Plex-Supported-Commands=abort&X-Plex-Token=...7NNH
11-23 20:58:54.788  i: [RefreshRateBehaviour] Disconnecting
11-23 20:58:54.789  i: [HdmiUnplugBehaviour] Disconnecting
11-23 20:58:54.839  i: Fetching [method:GET] https://192.168.1.130:32400/library/metadata/2764?checkFiles=1&includeExtras=1&includeRelated=1&includeRelatedCount=0&includeReviews=1&X-Plex-Token=...7NNH
11-23 20:58:54.879  i: [MediaSessionHelper] Releasing media session with tag: video
11-23 20:58:54.898  i: [UpdateRecommendationsService] Updating recommendations...
11-23 20:58:54.908  i: Fetching [method:GET] https://192.168.1.130:32400/hubs?X-Plex-Token=...7NNH
11-23 20:58:54.938  i: Resuming PreplayEpisodeActivity.
11-23 20:58:54.938  i: [UpdateRecommendationsService] 0 recommendations made from hub 'home.continue'.
11-23 20:58:54.939  i: [ThemeMusic] Playing new theme music.
11-23 20:58:54.961  i: [pms] /127.0.0.1:58963 - GET /proxy
11-23 20:58:54.964  i: [Proxy] Request received: https://192.168.1.130:32400/library/metadata/1696/theme/1511404488?X-Plex-Token=...7NNH
11-23 20:58:55.049  i: [Proxy] Response: 200
