Interesting results.
What are you playing the file on? I play to the browser (PLex/web) which is aac only, and it plays
Nov 03, 2018 02:36:04.035 [0x7fb43a7fc700] DEBUG - Auth: authenticated user 1 as ChuckPA
Nov 03, 2018 02:36:04.038 [0x7fb43a7fc700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 03, 2018 02:36:04.038 [0x7fb43a7fc700] DEBUG - Selecting best audio stream for part ID 3297 (autoselect: 1 language: en)
Nov 03, 2018 02:36:04.038 [0x7fb43a7fc700] DEBUG - Audio Stream: 7943, Subtitle Stream: -1
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: Selected protocol dash; container: mp4
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: analyzing media item 3292
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: filename-snip (2018): Direct Play is disabled
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: filename-snip (2018): media must be transcoded in order to use the dash protocol
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: filename-snip (2018): no direct play video profile exists for http/mkv/h264
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: filename-snip (2018): no direct play video profile exists for http/mkv/h264/eac3
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: Cannot direct stream audio stream due to codec eac3 when profile only allows aac
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - MDE: filename-snip (2018): selected media 0 / 3292
Nov 03, 2018 02:36:04.039 [0x7fb43a7fc700] DEBUG - Streaming Resource: Added session 0x7fb4040f0610:laq325q1eucotg4e49s7tg5f
Nov 03, 2018 02:36:04.040 [0x7fb43a7fc700] DEBUG - Streaming Resource: Reached Decision id=1637 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=3292 part=(id=3297 decision=transcode container=mp4 protocol=dash streams=(Video=(id=7942 decision=copy width=1280 height=720) Audio=(id=7943 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000))))
Nov 03, 2018 02:36:04.040 [0x7fb477fff700] DEBUG - Completed: [127.0.0.1:59886] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F1637&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=t409dwzfkofd29y8ob1j4t2j&subtitles=burn&Accept-Language=en (7 live) GZIP 6ms 1224 bytes (pipelined: 13)
Nov 03, 2018 02:36:04.102 [0x7fb47c919700] DEBUG - Auth: authenticated user 1 as ChuckPA
Nov 03, 2018 02:36:04.103 [0x7fb4397fa700] DEBUG - Request: [127.0.0.1:59886 (Loopback)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F1637&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=t409dwzfkofd29y8ob1j4t2j&subtitles=burn&Accept-Language=en (7 live) GZIP Signed-in Token (ChuckPA)
Nov 03, 2018 02:36:04.103 [0x7fb4397fa700] DEBUG - Found session GUID of t409dwzfkofd29y8ob1j4t2j in session start.
Nov 03, 2018 02:36:04.103 [0x7fb4397fa700] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Nov 03, 2018 02:36:04.103 [0x7fb4397fa700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/1637?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Session-Identifier=laq325q1eucotg4e49s7tg5f
Nov 03, 2018 02:36:04.103 [0x7fb4397fa700] DEBUG - Auth: authenticated user 1 as ChuckPA
Nov 03, 2018 02:36:04.105 [0x7fb4397fa700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Nov 03, 2018 02:36:04.105 [0x7fb4397fa700] DEBUG - Selecting best audio stream for part ID 3297 (autoselect: 1 language: en)
Nov 03, 2018 02:36:04.105 [0x7fb4397fa700] DEBUG - Audio Stream: 7943, Subtitle Stream: -1
Nov 03, 2018 02:36:04.106 [0x7fb4397fa700] DEBUG - Found session GUID of t409dwzfkofd29y8ob1j4t2j in session start.
Nov 03, 2018 02:36:04.106 [0x7fb4397fa700] DEBUG - Cleaning directory for session t409dwzfkofd29y8ob1j4t2j ()
Nov 03, 2018 02:36:04.106 [0x7fb4397fa700] DEBUG - Starting a transcode session t409dwzfkofd29y8ob1j4t2j at offset -1.0 (state=3)
Nov 03, 2018 02:36:04.107 [0x7fb4397fa700] INFO - CodecManager: obtaining EAE
Nov 03, 2018 02:36:04.107 [0x7fb4397fa700] DEBUG - HTTP requesting GET https://plex.tv/api/codecs/easyaudioencoder?build=linux-x86_64-standard&deviceId=62fdbbc5-e9ea-4f35-b70c-509d690e73bb&oldestPreviousVersion=1%2E13%2E6%2E5339-115f087d6&version=eae-69c1de6-14
This shows it obtaining the codec for decoding.
This being the case, I would like you to:
- Stop PMS
cd "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Codecs"
- Remove everything you see there with
*eae*, including the directory.
- Start PMS
- Play it again (letting the codec download again).
My suspicion is, given I’m running the next version of PMS in testing, is your codec somehow didn’t download correctly.
Deleting the files and letting them be fetched again will resolve that.
