EAE timeout causing sonic analysis to hang
Server Version#: 1.43.0.10492
Player Version#: 1.112.0.359-0d79a49f
I’m getting this error processing music
Mar 03, 2026 09:38:21.000 [139664706521912] ERROR - [Req#1784952/Transcode/e16b231f-0645-4688-ab64-3f6a405d5dfa/f6e17c60-c5cc-4662-848f-ed2bba130217] [eac3_eae @ 0x7390da8ee5c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-bb5e70df-c983-415e-b4b5-28ae3a10225b/EasyAudioEncoder/Convert to WAV (to 8ch or less)/e16b231f-0645-4688-ab64-3f6a405d5dfa_3017295-0-28.wav'
Mar 03, 2026 09:38:21.000 [139664704412472] ERROR - [Req#178495e/Transcode/e16b231f-0645-4688-ab64-3f6a405d5dfa/f6e17c60-c5cc-4662-848f-ed2bba130217] [eac3_eae @ 0x7390da8ee5c0] error reading output: -5 (I/O error)
Mar 03, 2026 09:38:21.001 [139664690977592] ERROR - [Req#178495f/Transcode/e16b231f-0645-4688-ab64-3f6a405d5dfa/f6e17c60-c5cc-4662-848f-ed2bba130217] [aist#0:1/eac3 @ 0x7390db5d0380] Error submitting packet to decoder: I/O error
Mar 03, 2026 09:38:26.000 [139664706521912] ERROR - [Req#1784960/Transcode/e16b231f-0645-4688-ab64-3f6a405d5dfa/f6e17c60-c5cc-4662-848f-ed2bba130217] [eac3_eae @ 0x7390da8ee5c0] EAE timeout! EAE not running, or wrong folder? Could not read '/tmp/pms-bb5e70df-c983-415e-b4b5-28ae3a10225b/EasyAudioEncoder/Convert to WAV (to 8ch or less)/e16b231f-0645-4688-ab64-3f6a405d5dfa_3017295-0-29.wav'
Mar 03, 2026 09:38:26.000 [139664704412472] ERROR - [Req#1784961/Transcode/e16b231f-0645-4688-ab64-3f6a405d5dfa/f6e17c60-c5cc-4662-848f-ed2bba130217] [eac3_eae @ 0x7390da8ee5c0] error reading output: -5 (I/O error)
Mar 03, 2026 09:38:26.000 [139664690977592] ERROR - [Req#1784962/Transcode/e16b231f-0645-4688-ab64-3f6a405d5dfa/f6e17c60-c5cc-4662-848f-ed2bba130217] [aist#0:1/eac3 @ 0x7390db5d0380] Error submitting packet to decoder: I/O error
I’ve tried:
  • Stopping plexmediaserver.service, deleting Codecs, and restarting the machine
  • Changing permissions in temp to 777
  • Changing permissions in the Plex Media Server data directory in /var/lib/plexmediaserver/Library/Application Support/Plex Media Server to 755 and 644 for directories and files, respectively
  • Changing fs.inotify.max_user_watches to 1048576 and fs.inotify.max_user_instances to 8192, then running sysctl -p and restarting plexmediaserver.service.
The error still persists, but I don’t see any other avenues to try. Any suggestions?
Is the folder location of the “Plex transcoder temp” mounted with NOEXEC? If so, this will prevent the EAE from running completely.
I don’t see /tmp in the list when I run findmnt -l | grep noexec
My transcoder temporary directory in Settings > Transcoder is set to /dev/shm, but that is not in the noexec list either, and transcoding other media work fine.
I am having the exact same issue. Have you found a solution?
eac3 @ 0x1464d0d10000] Error submitting packet to decoder: I/O error
Disabling “Include music libraries in automatic updates” seems to have “solved” the issue, but it doesn’t seem like it actually resolved the underlying problem.
The EAE is only used to decode and transcode audio codecs from Dolby.
I wonder why it would be engaged with music – unless you have TrueHD or (E-)AC3 music in your library.
Is there a way to see which file is causing the transcode request? I couldn’t find it in the logs. Seems like it just reports the temporary working folder.
If so, I could try to reproduce the error again and check what kind of file is causing the request.
