Server Version#: 1.40.1.8227 & 1.40.2.8395
Windows Version 1.91.0.129-1cd63c1d
Web Version 4.125.1
The last few days I seem to be having loads of problem transcoding even relatively simple files on my DS920+ .
HEVC at 720p is failing and h.264 at 1080p is also failing.
They all seem to issue this error:
[Req#22a8/Transcode/lwujm942ielfjqqmk91xyhic/619cd4ea-02e1-4761-9c58-a5b06f72a988] [eac3_eae @ 0x7f077be8eb80] EAE timeout! EAE not running, or wrong folder? Could not read '/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/pms-2c12feaa-aa98-469f-8d71-fd1d874b57b7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/lwujm942ielfjqqmk91xyhic_14454-0-1.wav'
I have seen from @ChuckPa that this can be an inotify issue, but I don’t see any such errors and my directories aren’t too big I believe. So not quite sure what is going on here?
Logs attached in debug with verbose off after stopping PMS package, restarting and then attempting a 2 files that fail and another that works.
Plex Media Server Logs_2024-04-30_11-57-44.zip (504.7 KB)
Thanks for the logs.
You’ve got ugliness going on in there.
- Manually clean up the
@eaDir (copy xxx) stuff
Apr 30, 2024 11:50:32.914 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR"
Apr 30, 2024 11:50:32.914 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports"
Apr 30, 2024 11:50:32.914 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 1)"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 1)/Andrea Mitchell Reports - S2022E1380 - Episode 1380.ts"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 2)"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 2)/Andrea Mitchell Reports - S2022E1381 - Episode 1381.ts"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 3)"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 3)/Andrea Mitchell Reports - S2022E1382 - Episode 1382.ts"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 4)"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 4)/Andrea Mitchell Reports - S2022E1383 - Episode 1383.ts"
Apr 30, 2024 11:50:32.915 [139718675270456] DEBUG - [Notify] Now watching "/volume1/video/TV-DVR/Andrea Mitchell Reports/Season 2022/@eaDir (copy 5)"
Go through your machine, find and delete ALL @eaDir entries (The DSM indexer is what creates them.
We will reboot and retest after you’ve got it all cleaned up
Supplemental:
Where is your transcoder temp set for? Is it at the default location?
Apr 30, 2024 11:52:39.000 [139718658132792] ERROR - [Req#3e0/Transcode/m9orx2x9tqhw0ts3ckuk7dlk/1bdd4d5d-8738-474c-97eb-1f2fee645a18] [eac3_eae @ 0x7fca22ac4580] EAE timeout! EAE not running, or wrong folder? Could not read ‘/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/pms-2c12feaa-aa98-469f-8d71-fd1d874b57b7/EasyAudioEncoder/Convert to WAV (to 8ch or less)/m9orx2x9tqhw0ts3ckuk7dlk_5211-0-22.wav’
Did you (your username) touch anything in the “PlexMediaServer” shared folder ?
I’ve removed all @eaDir using filestation and restarted and it still is throwing the EAE timeout error.
The tmp directory is located at:
/volume1/PlexMediaServer/AppData/tmp
Eveything has the username of PlexMediaServer - nothing has been touched by my username (especially since we cleaned that up a few weeks back)
New Logs attached
Plex Media Server Logs_2024-04-30_15-33-50.zip (1.8 MB)
sorry forgot to tag you in my reply @ChuckPa
Please open FileStation → PlexMediaServer / AppData
Now go into tmp and, with PMS stopped, delete everything you find.
Go back up one level and down into Plex Media Server / Codecs
DELETE all EasyAccessEncoder files and folders you find.
Go back up one level and make certain (Right-click Codecs → Properties) that Codecs is owned by PlexMediaServer
We definitely have a EAE problem here but I’m not sure how/why yet.
After you’ve confirmed that, Start PMS and try that one file again please
Done. And it seems to be playing now!
Quite a lot of files/folders in tmp that dated back to 2023 and even as far back as 2021.
The EasyAudioEncoder folder in Codecs was from Sept-23 and there was also an older .zip file from 2020.
Logs attached - in case it’s useful to figure out what went wrong.
Plex Media Server Logs_2024-04-30_21-54-20.zip (699.4 KB)
