Easy Encoder Error (13)
Server Version#:1.42.1.10060
I/m running Plex Media Server in a docker container on TRUENAS Scale24.10.2.4. I have Watchtower running to update the image. i have therefore been on the latest Media Server version above since it came out. All of a sudden i came to watch a some content one morning and i noticed the transcoding was failing and when i dug deeper i noticed it was the Audio it was trying to transcode and failing.
going into the shell i noticed every time i try to transcode a file the Easy Encoder fails to execute with error 13.
now i have searched and searched and everyone seems to say delete the folder and plex will re download after a PMS restart on next Transcode attempt. It indeed does this but doesnt fix the issue.
I equally have tried amending the permissions chmod +x -R EasyEncoder***
every time i try it just crashes saying it couldn’t transcode and in the docker bash i get the error 13 again.
Sep 01, 2025 22:22:03.903 [139966671633208] INFO - [Req#15e/Transcode] CodecManager: starting EAE at "/run/plex-temp/pms-c7a51295-4913-44e8-8dcd-f95a41d26c0b/EasyAudioEncoder"
Sep 01, 2025 22:22:03.903 [139966671633208] DEBUG - [Req#15e/Transcode/JobRunner] Job running: "/config/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-8f4ca5ead7783c54a4930420-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder"
Sep 01, 2025 22:22:03.903 [139966671633208] DEBUG - [Req#15e/Transcode/JobRunner] In directory: "/run/plex-temp/pms-c7a51295-4913-44e8-8dcd-f95a41d26c0b/EasyAudioEncoder"
Sep 01, 2025 22:22:03.904 [139966671633208] DEBUG - [Req#15e/Transcode/JobRunner] Jobs: Starting child process with pid 435
Sep 01, 2025 22:22:03.904 [139966671633208] DEBUG - [Req#15e/Transcode] [Universal] Using local file path instead of URL: /nasmedia/TV Shows/The Boys/Season 03/The Boys.S03E07.Here Comes a Candle to Light You to Bed.mkv
Sep 01, 2025 22:22:03.904 [139966906907448] DEBUG - Jobs: '/config/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-8f4ca5ead7783c54a4930420-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder' exit code for process 435 is 13 (failure)
Sep 01, 2025 22:22:03.904 [139966671633208] DEBUG - [Req#15e/Transcode] TPU: hardware transcoding: final decoder: , final encoder: nvenc
Sep 01, 2025 22:22:03.905 [139966671633208] DEBUG - [Req#15e/Transcode/JobRunner] Job running: CUDA_CACHE_PATH="/config/Library/Application Support/Plex Media Server/Cache/Shaders/CUDA" EAE_ROOT=/run/plex-temp/pms-c7a51295-4913-44e8-8dcd-f95a41d26c0b/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/46f74ab-560174306fe167a5978a79dd-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/usr/lib/plexmediaserver/Plex Transcoder" -codec:0 hevc -codec:1 eac3_eae -eae_prefix:1 3kze8kdn6fdofng24w19pl8m_ -analyzeduration 20000000 -probesize 20000000 -i "/nasmedia/TV Shows/The Boys/Season 03/The Boys.S03E07.Here Comes a Candle to Light You to Bed.mkv" -filter_complex "[0:0]scale=w=1280:h=720:force_divisible_by=4[0];[0]format=pix_fmts=yuv420p|nv12[1]" -map "[1]" -codec:0 hevc_nvenc -b:0 3319k -maxrate:0 3319k -bufsize:0 6638k -forced-idr:0 1 -r:0 23.975999999999999 -force_key_frames:0 "expr:gte(t,n_forced*3)" -filter_complex "[0:1] aresample=async=1:ochl='5.1':rematrix_maxval=0.000000dB:osr=48000[2]" -map "[2]" -metadata:s:1 language=eng -codec:1 aac -b:1 453k -f dash -seg_duration 3 -dash_segment_type mp4 -init_seg_name 'init-stream$RepresentationID$.m4s' -media_seg_name 'chunk-stream$RepresentationID$-$Number%05d$.m4s' -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name "http://127.0.0.1:32400/video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/manifest?X-Plex-Http-Pipeline=infinite" -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -start_at_zero -copyts -vsync cfr -init_hw_device cuda=cuda:pci:0000:d5:00.0 -filter_hw_device cuda -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress
Sep 01, 2025 22:22:03.905 [139966671633208] DEBUG - [Req#15e/Transcode/JobRunner] In directory: "/config/Library/Application Support/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-3kze8kdn6fdofng24w19pl8m-57415314-de42-43d2-9716-64ce6f7b9db1"
Sep 01, 2025 22:22:03.905 [139966671633208] DEBUG - [Req#15e/Transcode/JobRunner] Jobs: Starting child process with pid 436
Sep 01, 2025 22:22:03.915 [139966834060088] DEBUG - Request: [127.0.0.1:49338 (Loopback)] PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=startup (8 live) #150 Signed-in Token (snicholls) (range: bytes=0-)
Sep 01, 2025 22:22:03.915 [139966894447416] DEBUG - Completed: [127.0.0.1:49338] 204 PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=startup (8 live) #150 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Sep 01, 2025 22:22:04.029 [139966834060088] DEBUG - Request: [127.0.0.1:49338 (Loopback)] PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=startup (8 live) #162 Signed-in Token (snicholls) (range: bytes=0-)
Sep 01, 2025 22:22:04.029 [139966896556856] DEBUG - Completed: [127.0.0.1:49338] 204 PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=startup (8 live) #162 0ms 203 bytes (pipelined: 2) (range: bytes=0-)
Sep 01, 2025 22:22:04.029 [139966834060088] DEBUG - Request: [127.0.0.1:49338 (Loopback)] PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=opening (8 live) #163 Signed-in Token (snicholls) (range: bytes=0-)
Sep 01, 2025 22:22:04.030 [139966896556856] DEBUG - Completed: [127.0.0.1:49338] 204 PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=opening (8 live) #163 0ms 203 bytes (pipelined: 3) (range: bytes=0-)
Sep 01, 2025 22:22:04.032 [139966834060088] DEBUG - Request: [127.0.0.1:49338 (Loopback)] PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=opened (8 live) #164 Signed-in Token (snicholls) (range: bytes=0-)
Sep 01, 2025 22:22:04.033 [139966894447416] DEBUG - Completed: [127.0.0.1:49338] 204 PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress?status=opened (8 live) #164 0ms 203 bytes (pipelined: 4) (range: bytes=0-)
Sep 01, 2025 22:22:04.033 [139966834060088] DEBUG - Request: [127.0.0.1:49338 (Loopback)] PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress/stream?index=0&id=0&codec=hevc&type=video (8 live) #165 Signed-in Token (snicholls) (range: bytes=0-)
Sep 01, 2025 22:22:04.033 [139966894447416] DEBUG - Completed: [127.0.0.1:49338] 200 PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress/stream?index=0&id=0&codec=hevc&type=video (8 live) #165 0ms 195 bytes (pipelined: 5) (range: bytes=0-)
Sep 01, 2025 22:22:04.033 [139966834060088] DEBUG - Request: [127.0.0.1:49338 (Loopback)] PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress/stream?index=1&id=0&codec=eac3&type=audio (8 live) #166 Signed-in Token (snicholls) (range: bytes=0-)
Sep 01, 2025 22:22:04.034 [139966894447416] DEBUG - Completed: [127.0.0.1:49338] 200 PUT /video/:/transcode/session/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1/progress/stream?index=1&id=0&codec=eac3&type=audio (8 live) #166 0ms 195 bytes (pipelined: 6) (range: bytes=0-)
Sep 01, 2025 22:22:04.034 [139966834060088] ERROR - [Req#167/Transcode/3kze8kdn6fdofng24w19pl8m/57415314-de42-43d2-9716-64ce6f7b9db1] Unknown decoder 'hevc'
Sep 01, 2025 22:22:04.066 [139966906907448] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 436 is 1 (failure)
Sep 01, 2025 22:22:09.849 [139966834060088] DEBUG - Request: [192.168.1.201:52374 (Subnet)] GET /statistics/resources?timespan=6 (7 live) #154 TLS GZIP Signed-in Token (snicholls)
Sep 01, 2025 22:22:09.851 [139966894447416] DEBUG - Completed: [192.168.1.201:52374] 200 GET /statistics/resources?timespan=6 (8 live) #154 TLS GZIP 2ms 806 bytes (pipelined: 38)
Sep 01, 2025 22:22:09.858 [139966834060088] DEBUG - Request: [192.168.1.201:52457 (Subnet)] GET /statistics/bandwidth?timespan=6 (8 live) #161 TLS GZIP Signed-in Token (snicholls)
Sep 01, 2025 22:22:09.861 [139966896556856] DEBUG - Completed: [192.168.1.201:52457] 200 GET /statistics/bandwidth?timespan=6 (8 live) #161 TLS GZIP 2ms 1294 bytes (pipelined: 1)
Sep 01, 2025 22:22:10.592 [139966834060088] DEBUG - Request: [192.168.1.201:52457 (Subnet)] GET /statistics/bandwidth?timespan=6 (8 live) #16c TLS GZIP Signed-in Token (snicholls)
Sep 01, 2025 22:22:10.595 [139966894447416] DEBUG - Completed: [192.168.1.201:52457] 200 GET /statistics/bandwidth?timespan=6 (8 live) #16c TLS GZIP 2ms 1296 bytes (pipelined: 2)
Sep 01, 2025 22:22:11.597 [139966834060088] DEBUG - Request: [192.168.1.201:52457 (Subnet)] GET /statistics/bandwidth?timespan=6 (8 live) #16d TLS GZIP Signed-in Token (snicholls)
Sep 01, 2025 22:22:11.599 [139966894447416] DEBUG - Completed: [192.168.1.201:52457] 200 GET /statistics/bandwidth?timespan=6 (8 live) #16d TLS GZIP 2ms 1301 bytes (pipelined: 3)
Sep 01, 2025 22:22:12.294 [139966827731768] DEBUG - player m3qvtvfc0bfgdtgjyg28bd4c was last refreshed 19 seconds ago
Sep 01, 2025 22:22:13.905 [139966671633208] DEBUG - [Req#15e/Transcode] Using default transcode duration of 120 minutes
Sep 01, 2025 22:22:13.905 [139966671633208] DEBUG - [Req#15e/Transcode] Started session successfully: 3kze8kdn6fdofng24w19pl8m
Sep 01, 2025 22:22:13.906 [139966836169528] DEBUG - Streaming Resource: Changing client to use software decoding
Sep 01, 2025 22:22:13.906 [139966836169528] DEBUG - Found session GUID of 3kze8kdn6fdofng24w19pl8m in session start.
Sep 01, 2025 22:22:13.906 [139966836169528] DEBUG - TranscodeUniversalRequest: adapting profile with augmentation data: add-transcode-target(type=videoProfile&context=all&protocol=dash&container=mp4&videoCodec=h264,hevc&audioCodec=aac,ac3,eac3)+add-limitation(scope=videoCodec&scopeName=h264&type=upperBound&name=video.level&value=51)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.width&value=4096)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.bitDepth&value=8)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.frameRate&value=60)+add-limitation(scope=videoTranscodeTarget&scopeName=h264&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.bitrate&value=60000)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.width&value=4096)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.height&value=2160)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.bitDepth&value=10)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.frameRate&value=60)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=all&protocol=dash&type=upperBound&name=video.bitrate&value=80000)+add-limitation(scope=videoTranscodeTarget&scopeName=hevc&scopeType=videoCodec&context=all&type=match&name=video.colorTrc&protocol=dash&list=bt709|bt470m|bt470bg|smpte170m|smpte240m|bt2020-10|smpte2084&isRequired=false)+add-limitation(scope=videoCodec&scopeName=hevc&type=notMatch&name=video.DOVIProfile&value=5)+add-transcode-target-settings(type=videoProfile&context=all&protocol=dash&IncludeMapInEmptyVTT=true&BreakNonKeyframes=true)
Sep 01, 2025 22:22:13.907 [139966894447416] DEBUG - Completed: [192.168.1.157:58095] 200 GET /video/:/transcode/universal/start.mpd?Accept=application%2Fjson&Accept-Language=en-GB&directPlay=0&directStream=0&directStreamAudio=1&protocol=dash&fastSeek=1&path=%2Flibrary%2Fmetadata%2F52125&session=3kze8kdn6fdofng24w19pl8m&mediaIndex=0&partIndex=0&mediaBufferSize=50000&hasMDE=1&subtitleSize=100&videoQuality=100&videoResolution=1280x720&audioBoost=100&autoAdjustSubtitle=1&subtitles=none&maxVideoBitrate=4000&location=lan (8 live) #15e GZIP 10539ms 946 bytes (pipelined: 7)
Sep 01, 2025 22:22:13.907 [139966836169528] DEBUG - TranscodeUniversalRequest: using augmented profile Generic
Sep 01, 2025 22:22:13.907 [139966836169528] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/52125?includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=m3qvtvfc0bfgdtgjyg28bd4c
Sep 01, 2025 22:22:13.913 [139966836169528] DEBUG - [Req#17c] It took 0.000000 ms to retrieve 123 items.
Sep 01, 2025 22:22:13.915 [139966836169528] DEBUG - We're going to try to auto-select an audio stream for account 1.
Sep 01, 2025 22:22:13.915 [139966836169528] DEBUG - Selecting best audio stream for part ID 68894 (language: en)
Sep 01, 2025 22:22:13.915 [139966836169528] DEBUG - We're going to try to auto-select a subtitle for account 1.
Sep 01, 2025 22:22:13.915 [139966836169528] DEBUG - Audio Stream: 170953, Subtitle Stream: -1
Sep 01, 2025 22:22:13.917 [139966834060088] DEBUG - Request: [192.168.1.201:52457 (Subnet)] GET /status/sessions (8 live) #16e TLS GZIP Signed-in Token (snicholls)
Sep 01, 2025 22:22:13.917 [139966834060088] DEBUG - [Req#16e] [Now] Adding 0 sessions.
Sep 01, 2025 22:22:13.918 [139966896556856] DEBUG - Completed: [192.168.1.201:52457] 200 GET /status/sessions (8 live) #16e TLS GZIP 1ms 482 bytes (pipelined: 4)
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: Selected protocol dash; container: mp4
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: analyzing media item 68893
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: Direct Play is disabled
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: media must be transcoded in order to use the dash protocol
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: no direct play video profile exists for http/mkv/hevc
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: no direct play video profile exists for http/mkv/hevc/eac3
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - Here Comes a Candle to Light You to Bed - video.width limitation applies: 1920 > 1280
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: Direct Streaming is disabled, so video stream will be transcoded
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: no remuxable profile found, so video stream will be transcoded
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - MDE: The Boys - S3 E7 - Here Comes a Candle to Light You to Bed: selected media 0 / 68893
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - Streaming Resource: Calculated bandwidth of 10192kbps exceeds bandwidth limit. Changing decision parameters provided by client to fit bandwidth limit of 4000kbps
Sep 01, 2025 22:22:13.919 [139966836169528] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - Streaming Resource: Reducing playback quality for 3809kbps stream bitrate: audio channels to 6, quality to 10, disable audio DS as 640kbps is > the 336kbps available
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: Selected protocol dash; container: mp4
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: analyzing media item 68893
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: Direct Play is disabled
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: media must be transcoded in order to use the dash protocol
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: no direct play video profile exists for http/mkv/hevc
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: no direct play video profile exists for http/mkv/hevc/eac3
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - Here Comes a Candle to Light You to Bed - video.width limitation applies: 1920 > 1280
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: Direct Streaming is disabled, so video stream will be transcoded
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: no remuxable profile found, so video stream will be transcoded
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: E7 - Here Comes a Candle to Light You to Bed: Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Sep 01, 2025 22:22:13.920 [139966836169528] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - MDE: The Boys - S3 E7 - Here Comes a Candle to Light You to Bed: selected media 0 / 68893
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Streaming Resource: Session 0x7f4c91a6ee58:m3qvtvfc0bfgdtgjyg28bd4c changed from using 3961kbps to 3668kbps of WAN bandwidth.  Used bandwidth is now 3668kbps
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Streaming Resource: Reached Decision id=52125 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=68893 part=(id=68894 decision=transcode container=mp4 protocol=dash streams=(Video=(id=170952 decision=transcode bitrate=3157 encoder=libx264 width=1280 height=720) Audio=(id=170953 decision=transcode bitrate=336 encoder=aac channels=6 rate=48000))))
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Transcode Session: Going to restart at offset 0.000000 with segment number -1
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Killing job.
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Signalling job ID 436 with 9
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Job was already killed, not killing again.
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Stopping transcode session 3kze8kdn6fdofng24w19pl8m
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - Starting a transcode session 3kze8kdn6fdofng24w19pl8m at offset 0.0 (state=3)
Sep 01, 2025 22:22:13.921 [139966836169528] DEBUG - TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Sep 01, 2025 22:22:13.921 [139966836169528] WARN - CodecManager: EAE exited with code 13. Restarting.
Sep 01, 2025 22:22:13.921 [139966836169528] INFO - CodecManager: starting EAE at "/run/plex-temp/pms-c7a51295-4913-44e8-8dcd-f95a41d26c0b/EasyAudioEncoder"
Sep 01, 2025 22:22:13.923 [139966836169528] DEBUG - [JobRunner] Job running: "/config/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-8f4ca5ead7783c54a4930420-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder"
Sep 01, 2025 22:22:13.923 [139966836169528] DEBUG - [JobRunner] In directory: "/run/plex-temp/pms-c7a51295-4913-44e8-8dcd-f95a41d26c0b/EasyAudioEncoder"
Sep 01, 2025 22:22:13.923 [139966836169528] DEBUG - [JobRunner] Jobs: Starting child process with pid 440
You set the transcoder temp to /run ?
Error 13 is Permission Denied.
[chuck@lizum ~.2001]$ perror 13
Exit code(13): error "Permission denied"
[chuck@lizum ~.2002]$
The default permissions for /run is usually 755 meaning non-root users have no write permission.
drwxr-xr-x   50 root  root  1480 Sep  1 08:01 run/
so i rebooted the host and had some other issues i ended up deleting the container and rebuilding to fix a few other little issues and so this is no longer an issue.
