editing metadata...
whenever i load new video media into my plex server sometimes gets the metadata really really wrong… like classifying christopher eccleston’s run on doctor who as it’s christopher lowell (home improvement show) any ideas or programs i can use to fix my file’s data or am i hosed.
  1. https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Season-Based-TV-Shows
  2. https://forums.plex.tv/discussion/comment/1470625/#Comment_1470625
1st rule of getting Plex to name correctly is:
Follow the naming conventions exactly.
2nd rule of getting Plex to name correctly is:
FOLLOW THE NAMING CONVENTIONS EXACTLY!!
3rd rule of getting Plex to name correctly is:
There is no third rule.
https://support.plex.tv/hc/en-us/articles/200220687-Naming-Series-Based-TV-Shows
https://support.plex.tv/hc/en-us/articles/200381023-Naming-Movie-files
The only thing to add to those is that for TV shows the date in parenthesis is more important than it used to be and folder names and structure is much more important than the names of the files themselves.
Edit: FileBot will fix a lot of problems. Use this string as a starting point for TV shows:
{n.replaceTrailingBrackets()} - {s00e00.lower()} - {t}
Come on Otto: Provide more than just the links. After all what fun is there in that if you cannot be at least a little snarky and maybe a bit funny.
ok those help… sort of. but i’m still having the same problem with doctor who, the files are named right, but it’s still coming up as christopher lowell…
e: v\doctor who\09 - christopher eccleston\Doctor Who - 1x01 - Rose
where am i going wrong… helpful advise needed, snark is not please and thank you.
for the record, the matt smith and david tennant episodes follow the same naming scheme and nothing went wrong with them.
Then consider yourself very lucky.
This e: v\doctor who\09 - christopher eccleston\Doctor Who - 1x01 - Rose will not work.
What Doctor Who series?
What season?
These are the questions you must ask and answer yourself because Plex cannot understand your naming logic.
Here is a hint.
Doctor Who (2005)\Season 01\Doctor Who (2005) - s01e01 - Rose
Or, if you want to get fancy…
Doctor Who (2005)\Season 01 [9th Doctor, Christopher Eccleston]\Doctor Who (2005) - s01e01 - Rose
