EIA_608 subtitles making PMS crash
Server Version#: 1.15.5.994
Player Version#: Version 3.97.4 WebPlayer, Plex on Android
Logs: Plex Media Server Logs_2019-05-06_17-55-21.zip (1.6 MB)
I’m at all loss, the source files contain no actual hardcoded subs, the subs are always ‘unknown’ and this issue has arisen since the laste PMS update. I only want Subzero to deal with subtitles and somehow PMS now sees subtitles where there none, occasionally there are subs available for shows that have none either and I can’t figure out what is downloading them.
I’ve reinstalled entirely and recreated my database etc from scratch without Subzero as an agent recently.
Are you running Plex Media Server.exe as a Service or Scheduled task ?
I can see crashes in the intel hardware transcoder dll mfx_mft_h264ve_32.dll which is known to crash when Plex Media Server is run without a desktop as a service or scheduled task
Options available to you
  • do not run Plex Media Server as a service or scheduled task or via RDP, or
  • or disable hardware transcoder in server transcoder settings
I realised the logs I added were the wrong ones for the time being, but that sure could explain at least one type of crashing. What would you recommend for keeping the Plex Service running without desktop?
I’ll go reproduce the issue and present the logs, thanks in advance for the help!
Disable hardware transcoding
It is ‘an either or’ as i said when I gave the 2 options
Plex Media Server Logs_2019-05-18_14-48-49.zip (1.2 MB)
Plex is no longer running as a Service, but was recently updated to the latest PMS version: 1.15.6.1079
Whenever an EIA_608 subtitle is present and start, PMS crashes.
You have crash reporting disabled
May 18, 2019 14:48:32.720 [13088] WARN - Crash: Crash reporting disabled
If you have the windows option to create application dmp files, you may find them here
C:\Users\Leroy\AppData\Local\CrashDumps
The intel encoder is still implicated
May 18, 2019 14:44:26.281 [3620] INFO - [FFMPEG] - MFT name: 'IntelΠQuick Sync Video H.264 Encoder MFT'
May 18, 2019 14:44:26.490 [1436] WARN - Crash: Crash reporting disabled
Have you updated this driver recently?
Do you use RDP ?
