Embedded Collection metadata not read with New Plex Agent
Server Version#: 1.22.2.4282
I add embedded collection (ALBUM) custom data to my mp4 movies with mp3tag and the old movies agent always pulled my collections data into the tags>collections field, been using this for a long time. If I add new data I would refresh the movie metadata and it is pulled in.
The new agent does not want to pull in my tags>collections tag on new movies I add and existing movies I edit. If I refresh the movie metadata or it reads new movie it ignores it. it will though read new images so that works.
I have both settings enabled (prefer local metadata and prefer local metadata)
I perform the Upgrade matching originally, I did not only change agents . existing movies that had collections already imported into plex still seem to have those collections but not newly added movies.
  • The collections field(s) is not locked.
  • The Minimum automatic collection size is also set to 1 just for in case although this should not affect the reading of the collections tag on the actual movie.
  • I have also created a brand new Collection library for testing and added a new movie with existing embedded collection data and it was ignored.
  • I simplified the movie name to only Title and date to make sure the name wont affect it in anyway
  • Since the new collection is new things like refresh all metadata should not be needed but i also tried that.
  • I added the following metadata description , genre and something else and that was read, so it appears it is not reading the collections or ALBUM tag anymore
Any suggestions as to what can be done to get it to read embedded collections again.
This will be fixed in PMS 1.23.0 which is the next release.
Awesome, and thanks.
While i have your attention and you are fixing things, please fix Roku client to be able to add items to playlists. Without this feature why even bother to have playlists on Roku. :slightly_smiling_face:
Thanks again.
