Is there a way do show the English titles to my movies instead of local (Danish) titles?
I’m struggling to get my movies on the plex server to be shown in English rather than Danish. Is there a way?
If you disable ‘localized titles’ in the preferences of the ‘Plex Movie’ agent, you will get all Original titles for your movies.
Which may not be exactly what you want if you have also movies from non-english countries.
Second option:
You can set the language of your movie library to ‘english’. (‘edit’ your library)
But this will then cause all metadata to be in english.
Existing movies will remain in danish, though. Unless you perform a ‘Fix Match’ operation on each single movie, during which you can change the language.
Thank you very much for your elaborate respond sir!
