Enigma2 support for Plex DVR/LiveTV!
looks great! B)
Looking good, thanks.
Hey Andy,
just downloaded the latest version from github and put all the files from /src folder to
/usr/lib/enigma2/python/Plugins/SystemPlugins/PlexDVRAPI
but the plugin fails to start or to be shown. I’m using the latetst VTI-Image…
Updated manual to version 2.1, i can Now select a bouqet and its working again within plex. Thanks.
The only thing a noticed is that te plug-in starts realy slow and with spinners.
it all depend on how many channels you have, it needs to read them all to allow you to have a selection to choose from.
@RSchally said:
Hey Andy,
seems VTI is missing a bit of code, I’ll try to work around it.
EDIT: can you try this file please. unzip & upload to /usr/lib/enigma2/python/Plugins/SystemPlugins/PlexDVRAPI/ and restart e2.
Thanx… but no success or do I have to set the rights for some files?
same result?
Same result…
ok a fix has now been committed, https://github.com/OpenViX/PlexDVRAPI/commit/bf636e786fa1bb1065ece3868dbacf985a174658
Hello
I use the VTI Image and i have copy all files from your Github
from
/src
to
and set the folder and files to 755. Then i restart the box and now when i go to the plugins i have the same error like @RSchally
What i make wrong?
Greetings
It works i use the fix from today and now it’s going.
Thank you very much
Hello @andyblac1974 and congratulations.
I have not yet been able to try the plugin, but the look is great.
I have a dm7020hd, dm8000 and dm500hd but I do not know if there is any image that is already compatible with the plugin.
What is the best enigma2 device currently available? vu+ ultimo4k ? and not 4k, only hd device?
Thanks.
Imo, anything with more than 1 tuner is fine.
I installed OpenPli 6 which provides PlexDVR in the plugins.
Installed it and chose to use only one favorite bouquet. Unfortunately, it did find 0 channels, maybe because they are IPTV channels.
Since then, when I launch the plugin again, the box crashes with the following message in the crash log:
Traceback (most recent call last):
  File "/usr/lib/enigma2/python/Components/ConfigList.py", line 75, in selectionChanged
  File "/usr/lib/enigma2/python/Plugins/SystemPlugins/PlexDVRAPI/plugin.py", line 202, in populate
KeyError: ''
Any idea how I can launch it again with no crash and how I can have my IPTV channels?
Thanks.
hi, pm me your bouquets, but yes, atm it may have issues with iptv channels.
if you can get me your bouquets i’ll try to code for them. or skype me andyblac, as for clearing settings, look in /etc/enigma2 look for anything starting DVB and delete it, also with e2 stopped look in the settings file same location and look for a line starts with plexdvr.
next update will support IPTV bouquets :smiley:
Hi @andyblac194
I had you plugin working great for while but now plex is not able to see my vu+ box. After a plex restart i can go to the setup plex dvr page it sees my box but then after 30 seconds it disappears, i then try manually adding the address and its not there either. Have you any ideas let me know if you want some logs.
Many thanks
@jamesdisco said:
Hi @andyblac194
Many thanks
what version of plugin are you using ?, have you tried deleting the setup and starting fresh, press yellow whilst in the plugin. then setup again and remove from plex and re-add.
I’m on version 2.0, i’m using the latest version of openvix 5 0 023. Ive tried a few times resetting the plugin and ive reset the box. If i flash from a USB will that give me a clean machine, ive noticed doing a reset still keeps some of my settings.
