Hello, I am curious how long it takes the EPG guide data to be fixed once it’s reported via the spreadsheet above? The one channel I reported, as the rest seem fine, is roughy +30 seconds off. I keep getting the last 30 seconds of the previous show. I look forward to your reply.
Thanks,.
Have you tried viewing that channel on a TV, not using Plex? Is the channel always broadcasting shows at 30 seconds from the actual start. You could also add 1 minute of post recording padding to the show to ensure you always get the end of the show.
its not when I view via channels, it just seems the EPG for plex for that channel is 30 seconds off. I am getting the whole recording including the previous 30 seconds from the program before.
