EPG is 16 hours behind
Everything listed in the “Watch Now” section is from 16 hours ago. How do I fix this?
Check out what you have for your DVR settings. From Plex Web go to Settings -> Server -> Live TV & DVR. Then click on DVR Settings in orange. Scroll down and check Enable more frequent program guide refreshes, which will refresh the guide at 9 AM, 1 PM, and 5 PM as well as during maintenance.
I already have that setting turned on. Also, that would not explain why items listed under “Watch Now” are from 16 hours ago.
What OS are you running and what version of Plex Media Server?
Does the system clock on your computers show the current time and is it set to the correct timezone?
Are you using another client or viewing the Program Guide in the web browser on your server?
Window 10, 64-bit. And yes it does.
I’m using the web browser, Chrome.
Sent from my iPhone
On the server?
No, I’m using chrome to access the server from my laptop. It’s an Unraid server, there’s no browser.
Sigh, I’m a dumbass. The system clock on my computer was right, however the system clock on the Unraid was off by 16 hours for some reason. I’ve reset the clock and rebooted the server, problem solved. Thanks for your help.
Glad to walk you thru the possibilities!
