Starting Recording 24hrs early/Program Guide Time is off
Hello, So I Just bought Plex. and a scanner, The program guide is somehow wrong for me/Starts DVRing way to early. Because Hawaii 5o airs on Fridays at about 9pm (-10 GMT HST). But it started recording today Thursday (I wanna say the late night show?)…
Im sorry if this is really confusing and nonsense but I have no idea on how to fix this or even where to look or start to look on how to fix this…
Web Version 3.49.1
Server Version 1.12.3.4973 Drobo
Thank you.
If you are in Hawaii then its probably DST issues related to the guide data and GMT offset. When I was living in Hawaii I had the same issue with MythTV. Determine if it is EXACTLY 1h off. With MythTV I would have to force a full EPG refresh before it worked properly. Kodi later started caching EPG which broke the data for LiveTV playback.
If only the U.S. could decide on whether or not to have DST and apply that consistently.
I’m having a similar issue. I’m in Madison Wisconsin and the guide was based on my zip code which I did enter correctly yet the guide has everything an hour or so early. But seeing your posts from April it looks as though we don’t really get support.
What Plex Media Server version? What is Plex running on? Is the time set correctly on the device running Plex? I recall one user running Plex on a NAS discovered after several posts/replies that the NAS device he thought had the correct time did not actually.
