I have attempted to get the EPG working and have looked through the forums and other ones and cannot get this figured out.
I have a FreeNAS based plex server that I am running two HDHomeRun devices for my OTA and I also subscribed to Premium channels through HDHomeRun. I cannot get the EPG to show the proper shows so it will not properly record channels for me. I am located in the central portion of the USA (TEXAS) and would like to have my EPG record the correct shows. I attempted to mess with the EPG123, but cannot figure out the system and no idea where the XMLTV file is being saved if it is. My fiance just moved in and coming from satellite the expectations of this system need to be met. Please help with this so I can get things running correctly.
Correct. Plex does not support this configuration.
You can vote for implementation of supporting this specifically:
And/or vote for EPG support for multiple tuners:
Another route is to set up a process that creates the guide data for you (XMLTV). Here are the posts that might cover that (found via search):
https://forums.plex.tv/search?q=hdhomerun%20premium%20xmltv
WHY can’t PLEX use the EPG from HDHOMERUN since it has the correct guide.
This is very frustrating. I’m glad Plex added the EPG for HDHOMERUN-east, For now I have to record OTA thru HR and Premiun thru Plex.
Hopefully Plex will ether let you select TWO EPG or get the guide from HR.
If you want to get epg123 up in order to have both OTA and premium, msg me and I’ll help you out. The XMLTV file is saved in C:\ProgramData\GaRyan2\epg123\output\epg123.xmltv if you installed in the default location.
