I am operating a Plex server in Sinology nas.
other TV episodes look good in the library.
However, more than 1,000 TV episodes are not shown in the library.
Anything less than 999 episodes appear in the library.
Help me see more than 1,000 episodes as show in the library.
thinks.
##Preparation:
Go to Settings - Server - Agents - Shows - TheTVDB
In there, grab the line ‘Local Media Assets’ with your mouse and drag it downwards, so it ends up being at the bottom of the stack of active agents.
Repeat the same under
Settings - Server - Agents - Shows - TheMovieDatabase
Settings - Server - Agents - Movies - Plex Movie
Settings - Server - Agents - Movies - TheMovieDatabase
##then
- Look up your show on TheTVDB
- Take the title as it is used on TheTVDB. If there is something in parentheses, take that too. If the title contains invalid characters (depends on your file system), like
§ : % *, simply leave them out. - Check the naming and the folder structure of your show. Name the top folder of the show exactly after the title on TheTVDB. No abbreviations. No additional subfolders. No aliases.
- Name the episode files according to the above linked naming guide. Use the same title as for the top folder.
Show's Title - s01e01 - additional info.ext(’- additional info’ can be left out) - After you corrected the naming and folder structure, perform the Plex Dance with all files for this show.
