Hello,
I’m a mew Plex Server user and I noticed on some of the T.V. series that I’m adding some episodes populate with no problem and others only populate with the episode number.
All of my files are named consistently based on the naming convention recommendation (Sxx Ep xx.ext) I also made sure that the TVDB agent was first on the list. I could copy and paste the information from The TVDB.com into the Plex Media server but that would take forever.
Any ideas?
Thank You,
Rich
Server Version#: 1.21.1.3876
Hello,
After renaming the whole season using sxxexx and updating the libraries the episodes still only show the number.
Anything else I can try?
Thank You,
Rich
Now that you have the filenames, verify that the folder structure is also according to the requirements.
Hello,
Here is how I resolved the issue for all my T.V. Shows
Renamed all episodes in all seasons using sxxexx
Removed media from Plex Server (which also sent
everything to my Recycle Bin)
Restored files from Recycle Bin
Updated Libraries on Plex Server
Verified all episode names were present
I had one episode that didn’t have a screen capture (poster) for the episode so I created one to use and it worked great.
Thank You,
Rich
Dan_Bev
January 22, 2021, 10:01pm
6
Follow this guide if you need to do this in the future. Going to the recycle bin can be risky.
The Plex Dance
The purpose of this is to remove all cached metadata and xml data for an item that Plex usually keeps. This helps when you want to “start from scratch” for particular item
move all files for the media item out of the directory your Library is looking at, so Plex will not “see” it anymore
scan the library library (to detect changes)
empty trash
clean bundles (in menu next to server name, when accessed under ‘More’)
double check naming schema and move files back
scan the library
Support articl…
system
Closed
April 22, 2021, 10:01pm
7
