As you can see I have figured out how to do seasons on there. My problem is some files are merging together and I have no idea how to get them to show in the correct order.
The first one on there is original pilot. Now that originally showed correctly but when I added new files to the drive in a separate folder it showing that as the original pilot and not where it should be.
I have added the loose cannon recons to the collection and there are some intro and other extra stuff.
From this screenshot u can see the episodes have different names but still merging incorrectly. Any ideas how I can get these showing properly on Plex for streaming
D:/A TV Show Library Folder/ <--- Library 'Add Folders' aimed here - ONLY
......Doctor Who/
.........Season 01
...........Doctor Who - S01E01 - An Unearthly Child [All the crap that's NOT a file name goes in here].mp4
...........Doctor Who - S01E02 - The Cave of Skulls [All the crap that's NOT a file name goes in here].mp4
.............and so on..........
What about those intros. They are the ones I am having issues with. They are not proper episodes just the original actors introducing the missing recon episodes. Extras if u like. So like galaxy four say it was S03E01 and the intro, would I have to do that as S03E00?
Also I won’t be using the root of D when it setup. I was using that as a temporary place to try and get it working before I move it to it’s home on the E:/doctor who folders.
You can name and structure like TVDB - as I have shown.
Or you can Fix Match/Search Options/Agent/Personal Media
then hand edit every single item.
Plex won’t work like you want it.
It’s a TV Show and MUST follow TV Show guidelines or you create the New TV Show you want - one episode at a time - by hand.
TV Shows have to adhere to naming and structuring guidelines - 'cause they have to match against TVDB’s database… unless you want to hand edit each one (Personal Media).
Dr. Who - S01E01.mp4
Dr. Who - S01E01 - An Unearthly Child.mp4
Dr. Who - S01E01 - An Unearthly Child [Four Score and Seven Years Ago...blablabla].mp4
^all those are ‘Compliant’ File names and should all go in a
Season 01
folder
[everything in Brackets is ignored - so you can put all the crap in here]
I would think you would first name and structure to get your matches - then make a playlist - or just copy select episodes into a ‘Fake Dr. Who Show’ with Personal Media as your Agent - so Plex won’t complain - and make that fake show Your Special Show in whatever way you choose.
