Error 10013 while trying to access socket 80
PlexConnect : ***
PlexConnect : PlexConnect
PlexConnect : Press ENTER to shut down.
PlexConnect : ***
PlexConnect : IP_self: 10.0.1.10
PlexGDM : ***
PlexGDM : looking up Plex Media Server
PlexGDM : ***
PlexGDM : servers discovered: 2
PlexConnect : PMS: 10.0.1.10:32400
DNSServer : ***
DNSServer : Starting up.
DNSServer : intercept trailers.apple.com: 10.0.1.10
DNSServer : forward other to higher level DNS: 10.0.1.10
DNSServer : ***
WebServer : Failed to connect to port 80 (http): [Errno 10013] An attempt was ma
de to access a socket in a way forbidden by its access permissions
  • ATV model 2, firmware 5.2.1,
  • DNS: 10.0.1.1 (router) , changed to 10.0.1.10 (server)
  • Windows Server 2012
  • Local IP for PMS & PlexConnect: 10.0.1.10
Have turned off IIS and I'm not using a dns server, except for the router. Also created firewall exceptions for all ports for python.
What can I do to get this to work?
What the output of netstat?
Lists only the port for PMS, nothing else. netstat -a -n -o gives me everything, but there is nothing for port 80. It's completely open and unused. But PlexConnect cannot access it.
http://pastebin.com/nGq3kw8d
This is the output from netstat -anb. Anything useful?
http://stackoverflow.com/questions/3985127/what-does-can-not-obtain-ownership-information-in-netstat-ab-mean
So I used >net stop HTTP< to kill off a ton of things that were running, and that did it. Thanks for the help!
EDIT: Restarted and killed IIS and Web deployment agent service and that did the trick.
:slight_smile:
Turning it off and on again or the reverse almost always works for any problem ;p
I faced the same problem, and my cause was Skype.  If that was the case for you, go to Skype-Options-Advanced-Connection.
Uncheck "Use Port 80..." and it worked for me.
Yeah Skype can be a PITA, i will add the specific steps you outlined to the wiki.
This worked for me. Put I cannot restart the Web Deployment Agent Service. My AppleTV also cannot connect to the internet when I set it to manual DNS. Could these be related?
