Error cleaning the waste bin of a big audio library manually
Server Version#: 1.25.4.5426 (same problem in previous versions)
if i want to clean the trash for my library this message pops up
normally it should looks like this
its a pretty big library with 670k tracks
That’s a HUGE amount of tracks.
My guess is that it’s simply a database or a WebClient timeout.
Try and optimize the database for a start, and might have to run it several times
it takes only 1 second after i hit that button and the message comes…
i also have another problem , see here
bad is that i already set up a new plex server because i had a corrupt database before.
normaly i would delete that library and set it up new. (not tryed yet, but last time, a year ago, i couldnt delete it and started a new server)
but this is audiobooks. it needs 100 hours to edit and still not everything is right.
the biggest nightmare is that it trys to match the artists/authors and dont respect my tags.
for example in the mp3 tag there is the name of the author which is Christoph Keese, Plex matches this to Christoph Busse the drummer. i have 2700 authors. i cant do this again and again
this is horrible
I suspect you might have a broken database
Could you zip it, upload somewhere, and then DM me the link, so I could check?
now i also tried to delete this library but it didnt work. i send you password per dm
thank you
Logs.zip (1.8 MB)
Database sadly broken :frowning:
Jan 26, 2022 11:53:02.908 [7056] ERROR - Thread: Uncaught exception running async task which was spawned by thread 6704: sqlite3_statement_backend::loadOne: database disk image is malformed
I suggest you try a repair
Ref: Repair a Corrupted Database | Plex Support
it did not work to repair it.
i found a db backup from october. with it restored i was able to delete the audiobook library.
thank you for your quick help
