Hi everyone,
I’ve been trying to setup the WinTV-dualHD for a while now, but I was never able to find any channels when scanning. I even went to all the trouble of buying another tuner to check if that was the issue (shipping all the way from UK isn’t cheap!)
After a lot of tinkering, I have figured out what the problem might be. It seems that PMS is not set up to scan for channels correctly for Colombia, as there is a difference in the channel bandwidth between the regular DVB-T and the one used here. This can be evidenced in the following phrase regarding the DVB-T decoders that must be used for non-digital TV’s:
“Despite using the same system, European decoders cannot be used as they do not have NTSC or a voltage of 110 or a 6MHz channel (they use 8MHz).”
This and the available channels (w/ respective frequencies) can be found here:
Wiki Colombia TV
I noticed this when I finally found a software that let me manually scan and adjust the channel bandwidth. It found all the channels!
I then tested scanning for channels within Plex, but “fooling” PMS that I was in Taiwan (they also use 6 MHz channels) and it found them all as well. The only issue is the EPG of course won’t match, so I can’t add anything to my server.
How can I manually tel PMS to search in 6 MHz channels or to let me add channels without a EPG?
Just a quick FYI:
Taiwan, Colombia, Panama and Trinidad and Tobago all use 6 MHz channels and it seems the last 3 countries have the same issue in the setup.
Hope we can eventually get this fixed and this helps anyone that’s been looking into this (I’ve been trying on-and-off since Nov 2017).
Thank you!!
