WinTV-dualHD - 'Loading countries...'
Plex recognizes the tuner, but fails to recognize my country (Israel) or at all.
I keep getting an indication of ‘Loading countries…’
What can I do and is there a solution?
Hauppauge
WinTV-dualHD
2 tuners
I’ve had similar problem and managed to solve using
https://app.plex.tv/desktop/
and not connecting via ip address and 32400 port
Great!!! I succeeded! Thanks for the solution!
But now I get this answer after the scan step:
“No channels found. Make sure your device has a signal from your antenna and try scanning again.”
Do you know now what the solution is?
I don’t think Israel is covered: Live TV EPG - The update you’ve been waiting for
Did you see it listed somewhere?
Probably really we are not connected … :frowning:
(No, Israel is not on the list … I tried other countries)
