It seems like theTVDB just got a new website: forums.thetvdb.com/viewtopic.php?f=3&t=47469
Maybe this has something to do with their API being down or new.
@âSwee Jinâ said:
Unfortunately, the suggestions offered by Skynet3_NZ and PlexBurst did not work for me. The images still did not load. Guess Iâll have to wait until the API is up and running again.> @PixelBurst said:@marshallhunter07 said:
Skynet3_NZ method did not work for me. I am still having the same problemIt works for me as well.
Hereâs what I had to do on a couple that had already been matched after doing the steps as described by Skynet3_NZ.
Select the ⊠menu on the item that is missing data, fix match. Click search options, and drop the Agent down to The Movie Database, then hit search and pick the match.
That should sort you out.
Thanks for the suggestion. Unfortunately, this only worked for some of the TV shows for me. I hope the TVdb API gets sorted out.
One last try with this one then -
Under libraries for the library thatâs affected, hit the ââŠâ menu. Then go A dvanced, scroll right down to the bottom and there should be Agent âTheTVDBâ with a dropdown at the bottom of that section. Switch that to âThe Movie Databaseâ then save changes. Finally hit the ââŠâ menu again for that library and ârefresh all meta-dataâ.
Let me know if it works!
Unfortunately the new site was released just about a month ago. This newest problem is relatively new so it is highly unlikely that the launch of the site had anything to do with it. The API itself might have been altered more recently however, or simply their servers that run and host it are having issues. But a fair guess at the very least!
I have the same problem. The TVDB has a new website and a new api. Please Plex Team: Fix this problem as soon as possible.
Does anybody know when this problem will be resolved? Thank you
The scraper shouldnât ever be hitting https://www.thetvdb.com/banners/, rather it should be grabbing the actual url for the image as returned by the API (https://www.thetvdb.com/banners/graphical/$IMAGE_NAME.jpg). Not sure why the scraper is doing that but itâs been reported to the Plex folks.
itâs been almost a week and still broke?
Hey,
This is due to an update of the theTVDBâs api. When the plugin is getting the path of an image, if the âthumbmailâ entry does not exists then it creats one by default.
banner_thumb = img_info.get('thumbnail', '_cache/%s' % banner_path)
â_cache/%sâ % banner_pathâ should be the default value if âthumbmailâ entry does not exits.
But at the moment the theTVDBâs api always return a value for âthumbmailâ, but it can be just an empty value.
You can fix it by modify the file /usr/lib/plexmediaserver/Resources/Plug-ins-XXXXX/TheTVDB.bundle/Contents/Code/_init_.py (on linux)
line 1128
change
with
if banner_thumb == '':
banner_thumb = '_cache/%s' % banner_path
Here a pastebin with the modified file pastebin.com/V1SsnuBP
If you are not sure about what you are doing, dont try it.
Dont forget to make a backup of your _init_.py file
@Kirua29 said:
Hey,This is due to an update of the theTVDBâs api. When the plugin is getting the path of an image, if the âthumbmailâ entry does not exists then it creats one by default.
â_cache/%sâ % banner_pathâ should be the default value if âthumbmailâ entry does not exits.But at the moment the theTVDBâs api always return a value for âthumbmailâ, but it can be just an empty value.
line 1128
change
with
banner_thumb = '_cache/%s' % banner_pathHere a pastebin with the modified file pastebin.com/V1SsnuBP
Thanks Kirua29! This has solved it. (Although I had to restart plex for it to detect the changes)
No problem !
Currently there is another problem about the choice of the cover. It does not take the most beautiful. The TVDBâs API does not appear to return user notes. ![]()
Hey guys,
I downloaded the latest beta version for plex just now and reloaded all metadata for my series and now everything came back!
Seems like the latest beta updated, resolves this issue
@âmerdian.dennis@gmail.comâ said:
Hey guys,I downloaded the latest beta version for plex just now and reloaded all metadata for my series and now everything came back!
Experiencing the same issue here.
I found the following fix in the change notes for the new beta version you mentioned:
Fixes:
(Metadata) Missing artwork for some TV shows (#8473)
Fixes:
Seems like the latest beta updated, resolves this issueExperiencing the same issue here.
Fixes:
Better fix for those with a Plex Pass so Iâll mark this as answered too.
Those of you like me without Plex Pass will have to deal with it, switch to moviedb, or make the changes required as in Kirua29âs post until the final release.
Thereâs a quick, backwoods style work-around as wellâŠ
Go to TVDB, right click on poster, âsave image asâ then drop it on the edit window:
Itâs quick and dirty, but itâll save having to hack things most people donât know how to hack and itâll save the pain and suffering of changing your TV Show Libraries to TMDB - that youâll be changing back later when you find out itâs not the miracle cure you thought it was ('cause TMDB sucks for TV Shows).
Wow that was fast. Update is out that fixes this on main branch - case closed.
