Server Version#:1.43.0.10231
Player Version#:Plex for LG, Client version 5.93.2, Platform version 9.2.4
QNAP TS-251, QTS 5.2.7.3297, Celeron J1800, 8Gb RAM
Hardware acceleration is enabled and the device is shown as ‘Intel Atom Processor Z36XXX/Z37XXX Series graphics and display’
Error shown on client - ‘Playback error - an unexpected playback problem occurred’
Hi All
I recently noticed that I now get the above error on SOME videos when playing back. Previously I had no issues at all, everything played back perfectly - the only change that I’m aware of, is that I’ve upgraded Plex (downloaded from the Plex website, and then manually installed through the App Centre as the QNAP provided version is outdated). Most of my videos still playback fine, but it’s only some that now give the error and didn’t previously.
I upgraded to the latest release version v.1.42.2.10156 which gave the error, and then I tried upgrading again to the latest beta 1.43.0.10231, however the error persists.
If I go into the setting in the client (LG WebOS), and select Force Direct Play in the video options, the playback issue seems to be fixed, however I have not previously had to do this. If I turn it off, the error comes back again. There is no issue with playback on Windows however.
I think maybe it’s something to do with ffmpeg? If I watch the console output, these errors (amongst others) comes up -
[Req#1a2a/Transcode] [FFMPEG] - No support for codec hevc profile 2
[Req#1a2a/Transcode] [FFMPEG] - Failed setup for format vaapi: hwaccel initialisation returned error
[Req#1a2a/Transcode] Codecs: packet decode testing returned -95 for decoder ‘hevc’
Any help appreciated!
Bill
