Error s3014 s3015 s3016
Synology Server Version#: 1.32.4.7195
Web Player Version#: 4.110.1
I have the problem that the playback via the browser (Safari, Chrome, Edge) does not work.
I get the following error message:
An error occurred while playing " Blade " occurred.
Error code: s3015 (media)
However, if the movie is transcoded, it will play without any problems.
With other players (iOS, AndroidTV) it works fine
Need DEBUG server logs to see what’s happening.
It does sound like a player problem but the server logs will confirm.
(Android and iOS players are more capable than any web browser)
thank you for the effort
Plex Media Server Logs_2023-07-11_23-15-15.zip (4.5 MB)
Thank you for the log.
The problem here , the player (or specific TV) doesn’t support HEVC HDR (10 bit color)
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: Selected protocol dash; container: mp4
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: analyzing media item 80255
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: Blade (1998): Direct Play is disabled
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: Blade (1998): media must be transcoded in order to use the dash protocol
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: Blade (1998): no direct play video profile exists for http/mkv/hevc
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: Blade (1998): no direct play video profile exists for http/mkv/hevc/aac
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] Blade - video.bitDepth limitation applies: 10 > 8
Jul 11, 2023 21:30:48.473 [140680987355960] DEBUG - [Req#3a1ec3/Transcode] MDE: Blade (1998): no remuxable profile found, so video stream will be transcoded
When it transcodes,
  1. HDR is converted to H.264 SDR
  2. Bit rates are reduced per any applicable streaming (upload) limit or player requested quality limit.
Does this make sense to you?
I have another film where it works.
From which server log is the extract
Always look first at “Plex Media Server.log” as it is the most recent.
From there, work backward in time ; .1.log , .2.log, → .5.log
Files roll from 1->5 then roll off (deleted)
If there exist any references to other activities in the PMS log, look in the corresponding log for that subsystem
This movie works. Why
the sound is transcoded. can this therefore work?
I cannot confirm why something works from a 4-line snippet.
DEBUG log ZIP file please ?
Plex Media Server Logs_2023-07-12_18-02-02.zip (4.6 MB)
can you see something
@schawolf
I apologize for the delay.
  1. Your CPU is a xeon D-1527. It does not have HW transcoding capability. It’s also not very fast with HEVC . Synology selected this CPU because of its low power operation. It’s not a bad CPU. It’s a GREAT CPU for a NAS. It’s not so great for trying to play HEVC content. H.264 is a whole differerent matter.
  2. You are trying to play HEVC (Planet of the Apes)
  3. It must be transcoded and tone mapped down to H.264
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Operation not permitted
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Could not create hardware context for hevc
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Selected protocol dash; container: mp4
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: analyzing media item 33268
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Planet der Affen - Revolution (2014): Direct Play is disabled
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Planet der Affen - Revolution (2014): media must be transcoded in order to use the dash protocol
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Planet der Affen - Revolution (2014): no direct play video profile exists for http/mkv/hevc
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Planet der Affen - Revolution (2014): no direct play video profile exists for http/mkv/hevc/eac3
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Planet der Affen - Revolution - video.bitDepth limitation applies: 10 > 8
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Planet der Affen - Revolution (2014): no remuxable profile found, so video stream will be transcoded
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: testing h264_nvenc (encoder)
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: hardware transcoding: testing API nvenc
  1. There is no HW acceleration (QSV or Nvidia) available to use
Jul 12, 2023 10:32:03.295 [140681060526904] ERROR - [Req#3dbe7a/Transcode] [FFMPEG] - Cannot load libcuda.so.1
Jul 12, 2023 10:32:03.295 [140681060526904] ERROR - [Req#3dbe7a/Transcode] [FFMPEG] - Could not dynamically load CUDA
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Could not create hardware context for h264_nvenc
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] MDE: Cannot direct stream video stream due to profile or setting limitations
Jul 12, 2023 10:32:03.295 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: testing hevc (decoder) with hwdevice vaapi
Jul 12, 2023 10:32:03.296 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: hardware transcoding: testing API vaapi
Jul 12, 2023 10:32:03.296 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Generic error in an external library
Jul 12, 2023 10:32:03.296 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Could not create hardware context for hevc
Jul 12, 2023 10:32:03.296 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: testing hevc (decoder) with hwdevice nvdec
Jul 12, 2023 10:32:03.296 [140681060526904] DEBUG - [Req#3dbe7a/Transcode] Codecs: hardware transcoding: testing API nvdec
  1. Every possibility having been exhausted, it used Software Transcoding
    (This is where the CPU’s weakness causes you problem)
Jul 12, 2023 10:32:03.435 [140681062636344] DEBUG - [Req#3dbe7e/Transcode] Found session GUID of wg9d9shvsr7p3j85xv779iaz in session start.
Jul 12, 2023 10:32:03.435 [140681062636344] DEBUG - [Req#3dbe7e/Transcode] Cleaning directory for session wg9d9shvsr7p3j85xv779iaz ()
Jul 12, 2023 10:32:03.436 [140681062636344] DEBUG - [Req#3dbe7e/Transcode] Starting a transcode session wg9d9shvsr7p3j85xv779iaz at offset -1.0 (state=3)
Jul 12, 2023 10:32:03.446 [140681062636344] DEBUG - [Req#3dbe7e/Transcode] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Jul 12, 2023 10:32:03.446 [140681062636344] DEBUG - [Req#3dbe7e/Transcode] [Universal] Using local file path instead of URL: /volume1/NAS/Medien/Filme/Filme - Teil 1/Planet der Affen/Planet der Affen - Revolution (2014)/Planet der Affen - Revolution (2014).mkv
Jul 12, 2023 10:32:03.446 [140681062636344] DEBUG - [Req#3dbe7e/Transcode] TPU: hardware transcoding: final decoder: , final encoder:
Jul 12, 2023 10:32:03.447 [140681062636344] DEBUG - [Req#3dbe7e/Transcode/JobRunner] Job running: EAE_ROOT=/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/tmp/pms-a60d5ab4-cf0c-46b4-91e7-7a3943e05f10/EasyAudioEncoder FFMPEG_EXTERNAL_LIBS='/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex\ Media\ Server/Codecs/8217c1c-4565-linux-x86_64/' X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx "/volume1/@appstore/PlexMediaServer/Plex Transcoder" -codec:0 hevc -codec:1 eac3_eae -eae_prefix:1 wg9d9shvsr7p3j85xv779iaz_ -analyzeduration 20000000 -probesize 20000000 -i "/volume1/NAS/Medien/Filme/Filme - Teil 1/Planet der Affen/Planet der Affen - Revolution (2014)/Planet der Affen - Revolution (2014).mkv" -filter_complex "[0:0]scale=w=720:h=390:force_divisible_by=4[0];[0]format=pix_fmts=yuv420p|nv12[1]" -map "[1]" -codec:0 libx264 -crf:0 20 -maxrate:0 1716k -bufsize:0 3432k -r:0 23.975999999999999 -preset:0 veryfast -x264opts:0 subme=2:me_range=4:rc_lookahead=20:me=hex -force_key_frames:0 "expr:gte(t,n_forced*8)" -filter_complex "[0:1] aresample=async=1:ochl='stereo':rematrix_maxval=0.000000dB:osr=48000[2]" -map "[2]" -metadata:s:1 language=deu -codec:1 aac -b:1 167k -f dash -seg_duration 8 -dash_segment_type mp4 -init_seg_name 'init-stream$RepresentationID$.m4s' -media_seg_name 'chunk-stream$RepresentationID$-$Number%05d$.m4s' -window_size 5 -delete_removed false -skip_to_segment 1 -time_delta 0.0625 -manifest_name "http://127.0.0.1:32400/video/:/transcode/session/wg9d9shvsr7p3j85xv779iaz/999fc3f7-53a0-4187-a849-6e944a70b029/manifest?X-Plex-Http-Pipeline=infinite" -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 dash -map 0:3 -metadata:s:0 language=deu -codec:0 ass -strict_ts:0 0 -f segment -segment_format ass -segment_time 1 -segment_header_filename sub-header -segment_start_number 0 -segment_list "http://127.0.0.1:32400/video/:/transcode/session/wg9d9shvsr7p3j85xv779iaz/999fc3f7-53a0-4187-a849-6e944a70b029/manifest?stream=subtitles&X-Plex-Http-Pipeline=infinite" -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_format_options ignore_readorder=1 -segment_list_unfinished 1 -fflags +flush_packets "sub-chunk-%05d" -start_at_zero -copyts -vsync cfr -y -nostats -loglevel quiet -loglevel_plex error -progressurl http://127.0.0.1:32400/video/:/transcode/session/wg9d9shvsr7p3j85xv779iaz/999fc3f7-53a0-4187-a849-6e944a70b029/progress
Jul 12, 2023 10:32:03.447 [140681062636344] DEBUG - [Req#3dbe7e/Transcode/JobRunner] In directory: "/var/packages/PlexMediaServer/shares/PlexMediaServer/AppData/Plex Media Server/Cache/Transcode/Sessions/plex-transcode-wg9d9shvsr7p3j85xv779iaz-999fc3f7-53a0-4187-a849-6e944a70b029"
  1. Almost immediately thereafter. subtitles are invoked. (Always software encoded/burned)
Jul 12, 2023 10:32:04.597 [140681449470776] DEBUG - [Req#3dbe6f] We're going to try to auto-select an audio stream for account 1.
Jul 12, 2023 10:32:04.597 [140681449470776] DEBUG - [Req#3dbe6f] Selecting best audio stream for part ID 343422 (language: de)
Jul 12, 2023 10:32:04.597 [140681449470776] DEBUG - [Req#3dbe6f] We're going to try to auto-select a subtitle.
Jul 12, 2023 10:32:04.597 [140681449470776] DEBUG - [Req#3dbe6f] Subtitles: Found a candidate subtitle language [de] for a foreign film
Jul 12, 2023 10:32:04.597 [140681449470776] DEBUG - [Req#3dbe6f] Audio Stream: 890379, Subtitle Stream: 890381
Jul 12, 2023 10:32:04.602 [140681449470776] DEBUG - [Req#3dbe6f] [Now] User is schawolf (ID: 1)
Jul 12, 2023 10:32:04.602 [140681449470776] DEBUG - [Req#3dbe6f] [Now] Device is Safari (Safari).
Jul 12, 2023 10:32:04.602 [140681449470776] DEBUG - [Req#3dbe6f] [Now] Profile is Web
The system comes to a screaming haul with the errors you see.
The passmarks for the D-1527 aren’t bad but without HW to assist, it won’t handle HEVC . Especially cannot handle HEVC HDR
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+D-1527+%40+2.20GHz&id=3784
ok thank you
