Error with Xteve
Hi guys.
I’ve been trying to install the xteve plugin for several days.
Can someone tell me if it is still working or if there is any reliable alternative to be able to add TV channels to the plex.
Also if there is any way to add a list of iptv channels to plex
Greetings and thank you very much.
I dont visit the forum often, but I can tell you that I can currently using xteve with decent success. But “plugins” are no longer supported.
two tips.
  1. You need to make sure you are running Xteve in a docker or if on windows, installed on said machine. Plugins are not supported
  2. Make sure you are using Xteve 2.0 (or higher). 1.0 has issues
Many thx m8
Currently using xteve without issues… what issues are you having?
