The forum, as the name suggests, is for exchanging opinions, whether you like it or not. First try to understand, then criticize.
It’s been indeed hard to follow what seems like a waterfall of your opinions.
Not saying you cannot do it – just that it’ll make it harder for others to follow.
As for the earlier points:
did you install the Plex/Plexamp apk on the Eversolo and to select that as a streaming target in your regular Plexamp client?
The way I’ve read/interpreted the other post / thread, it’s not about the Eversolo as such just showing up as a streaming target but it actually requires the app to be installed.
My main, first entry concerns an idea for improving the functionality of the Plexamp application, but not the one currently built into eversolo. As I wrote earlier, in the EverSolo app for Android or directly in the EverSolo player, you can use Plex through it, but with less functionality because it only sees local files on the Internet and does not see your Tidal account. I would like and what I mean is the ability to control music on the local network and Tidal via the Plexamp application, but not the one built into Eversolo, only on Android and that is the main difference. The idea is to run the Plexappmp APK on your phone and control your music with it. I have nothing more to say and this is just a suggestion. I know the functionality of the Plexappmp application through EverSolo and I know how to do it. ps. that’s why I mentioned Roon remote because I mean this principle of operation. If someone doesn’t know how Roon remote works on Eversolo, let them find out.![]()
