Hello,
just wanted to let you know that Plex and Plexamp (both for Android) works very well on the new Eversolo dmp-a6 streamer/dac. Using Plex on my Android phone, I can even remote controll the Plexamp app on the Eversolo ![]()
Are you saying that the PlexAmp for Android is side loaded successfully to the Eversolo? Am I correct?
That is indeed correct, side loaded with an apk.
Yes, it work but limited by android, which is not bit perfect. But remote control work just fine
I wish there is some workaround or how they work on Lumin
