Every single track are created as an separat album
Hi guys,
like the title says, when I add new music to my plex server almost every track is created as
a separat album.
I tagged everything fine & its just for new music I add. Fu***** annoying…
When I create a new library, the albums which were correctly read before are now wrong.
Most songs are displayed as a single album which should be displayed as a single album.
Plex is up to date and runs on Windows 10
Pleeeease help, thank you very much :smiley:
This sounds similar to my issue I am having now. Let me see if I can explain my file structure and maybe get closer to the problem/issue.
E\Audio
E\Audio\Varios Artists
E\Audio\Panic! At the Disco
Etc…
Singles I will put in just the audio folder. Usually I strip out the ID tags and since i add songs every once in a while I would edit the info in PMS so it would have the right info.
Lately I dropped about 50+ songs singles, different genre, authors, etc… They all came in under someone elses name and most of them without any description. the Album shows like 20+ tracks all blank. I have to click edit on each to found out what the name is. Now I DON’T know, nor do I want them to have an Album associated with it. I just want it to be in my music library and I can search for it by name. Later on if/when I do figure out the album if it even has one, then yeah.
Is there a configuration setting that was missed, The files being imported used to work before in this fashion, but now everything imports under someone elses album or under its own Album. I want them to enter in as a Track, and only if I put in an album to associate it with that. Right now, my music library is so screwy It seems easier to just remove and restart all over again.
