Export library metadatas
Hi everyone,
I have a server A and B.
I have a folder “movies 1” that is on server B and metadata are matched properly.
I wish to stop server B.
So on server A I created a library using the same folder “movies 1”.
Unfortunately, the metatdas are incorrect on server A.
How can I export the library metadata from server B to server A?
thanks,
You cannot. You cannot merge data from several servers.
