I’ve been working on getting Plex to see my extras. I was having an issue with extras for the movie 300. I’m on Yosemite, running Plex Media Server 0.9.12.19. The issue I encountered is that with the 3 extras I imported placed in a Featurettes subfolder (/Movies/300 (2006)/Featurettes/), they were being imported as distinct movies (complete with appropriate metadata about each extra) and displayed right next to the main title.
I tried renaming them a few times, pored over the instructions for Local Media Assets, and searched the forums for advice. By chance, I tried renaming the subfolder from Featurettes to Scenes. This worked. The extras are now displayed in the movie “pre-play” screen. Is the “featurettes” category not working on OS X?
On a side note, I already had all the extras working under Kodi, but wanted to try to get them into Plex. My solution for using a single directory of movies with extras working in both Kodi and Plex is to create a hardlink to each extra, give it a descriptive name for Plex, and place it in the appropriate Extras_type subfolder.
Little more testing. It seems that the “Trailers” category is also not working properly. I am only able to get trailers to load if the folder is labeled “-Trailers”. Tried the same thing for “-Featurettes”, but that extra category still gets treated as a movie.
I had not. Mostly because the server was showing no updates available. How silly for me to assume it would have self-awareness about available versions.
I have the same structure as @BigWheel, but no Extras. One thing I noticed though, you have Trailers turned on and I don’t, so I just turned them on, For All Movies, and also I checked all three options just in case. I’ll check again tomorrow after maintenance. You do have Trailers turned on, right?
I was having the same problem - some Featurettes showing up as their own movies. I moved the Featurettes directory elsewhere, somewhere Plex can’t see. Then I moved it back where it belongs in the movie’s directory. This seems to have fixed it for me - they don’t get identified as their own Movies anymore after Plex re-scanned. Maybe Plex saw the items in the Featurettes directory before it saw the main movie file, so it started identifying them as Movies?
