Extras Other Folder
Server Version#: 1.30.1.6562
Player Version#: Version 4.87.2
Since the newest update Things add in the Other folder no longer uses the file name like it has been. For example: should show Demon Slayer - (S1) NCED - From The Edge but now it shows NCED before the update it was fine i just hit refresh and it change for some reason. Now it wont change no matter what i do but trailers ive added show named properly
Plex have introduced support for some alternative naming for opening/end themes; it appears those files are currently only picking up the “extra type” as a title and ignore the actual file name.
I know Plex are aware but don’t know if/when this will be fixed.
o well thank you for letting me know. Hopefully it gets fixed fast. i was panicking nothing wrong with having alternatives but i like plain and simple works for me
