I’m having similar symptoms and I’ve been having them for at least one month if not for longer. This doesn’t seem to have anything to do with the Enhanced Video Player, at least not for me.
No matter what I do there are several h265/MKV movies that I simply cannot play on my Apple TV 4K using the latest Plex-app for tvOS. First I thought it was the 4K h265 causing issues, so I grabbed the same movies in 1080P h264/MKV but still the same issues.
Using the Plex-app they won’t start at all. Just endless buffering and nothing ever happens. Rebooting my server, my switches, my router, my Apple-TV etc but nothing helps.
Using Infuse Pro the movies will start to play but after 1 min - 2,5 min it stops dead and continuously buffers as well.
After reading through this thread I tried several things:
Server Version#: 1.19.2.2673
Player Version#: 2.16
Apple TV 4K tvOS#: 13.4
Server-OS: Windows Server 2019 (17763.1158)
I tried disabling various offloading options on my Intel X550 NIC on my Windows Server. Didn’t change a thing. I tried to switch NIC’s from the Intel X550 10Gbit to Intel i211 1Gbit and Realtek 1Gbit NIC but same behaviour.
Tried to disable IPv6 (I have a fully deployed native IPv6 in my home but Plex insists on using IPv4 regardless according to the dashboard but I decided to try disabling IPv6 on the Plex server just to test) but still the same.
I tried to switch from using Ethernet on the Apple TV over to using WiFi as my Ubiquiti Access Points are connected directly to the same switch as my Plex-server, whereas my Apple TV running Ethernet is connected to another switch. Less cabling, one less network switch just for testing. Same results.
Testing using the Plex-app on our PlayStation 4 Pro and Xbox One X and everything works on them. They are running Ethernet to the very same switch as the Apple TV.
Playback of the same movies on my iPad Pro and iPhone is also working. It’s even working when my server has to transcode from 4K HDR H265/HEVC. It’s only the Apple TV and tvOS having issues.
Decided to even try to factory default my Apple TV 4K, but still the same.
Best regards,
Thomas Andre aka RamGuy
EDIT:
Never mind. After 20 min playback on the Xbox One X it also stopped and just kept on buffering forever. It’s really hard for me trying to grasp what is going on.
