Server Version#:v1.20.0.3110
Player Version#:v8.4.0.19279
On the QNAP everything is working perfectly, and yesterday I’ve tested and it was working on this device as well, also are the same time tested with a shared user and was working on his side…
Right now, I’m getting this error again and is not specific at all…
Looking at the log this is what I can see when I’ve tried to access to content
Jul 30, 2020 13:51:55.851 [0x6dce6450] DEBUG - Found session GUID of ----REMOVED-----com-plexapp-android in session start.
Jul 30, 2020 13:51:55.854 [0x6dce6450] DEBUG - TranscodeUniversalRequest: using augmented profile Android
Jul 30, 2020 13:51:55.855 [0x6dce6450] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/117?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=----REMOVED-com-plexapp-android
Jul 30, 2020 13:51:55.855 [0x6dce6450] DEBUG - Auth: authenticated user 1
Jul 30, 2020 13:51:55.881 [0x6dce6450] DEBUG - We're going to try to auto-select an audio stream for account 1.
Jul 30, 2020 13:51:55.881 [0x6dce6450] DEBUG - Selecting best audio stream for part ID 230 (autoselect: 0 language: en)
Jul 30, 2020 13:51:55.881 [0x6dce6450] DEBUG - We're going to try to auto-select a subtitle.
Jul 30, 2020 13:51:55.881 [0x6dce6450] DEBUG - Subtitles: Found a candidate subtitle language [eng] for a foreign film
Jul 30, 2020 13:51:55.881 [0x6dce6450] DEBUG - Audio Stream: 507, Subtitle Stream: 508
Jul 30, 2020 13:51:55.885 [0x6dce6450] DEBUG - Streaming Resource: Attempting to create AdHoc transcode session ----REMOVED-----com-plexapp-android
Jul 30, 2020 13:51:55.886 [0x6dce6450] DEBUG - Scaled up video bitrate to 23409Kbps based on 4.500000x fudge factor.
Jul 30, 2020 13:51:55.886 [0x6dce6450] DEBUG - MDE: Selected protocol hls; container: mkv
Jul 30, 2020 13:51:55.886 [0x6dce6450] DEBUG - MDE: analyzing media item 230
Jul 30, 2020 13:51:55.886 [0x6dce6450] DEBUG - MDE: The Banker (2020): Direct Play is disabled****
Jul 30, 2020 13:51:55.886 [0x6dce6450] DEBUG - MDE: The Banker (2020): media must be transcoded in order to use the hls protocol
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - MDE: The Banker (2020): selected subtitle cannot be converted to a compatible format, burning into video stream
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - MDE: The Banker (2020): avoiding video remux due to burned subtitle stream
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - MDE: The Banker (2020): no remuxable profile found, so video stream will be transcoded
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations*****
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - Scaled up video bitrate to 23409Kbps based on 4.500000x fudge factor.
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - MDE: The Banker (2020): selected media 0 / 230
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - Streaming Resource: Required bandwidth unknown (media requires deep analysis) Changing decision parameters provided by client to fit bandwidth limit of 720kbps
Jul 30, 2020 13:51:55.887 [0x6dce6450] DEBUG - Streaming Resource: Determining preferred transcode encoders through transcode only decision.
Jul 30, 2020 13:51:55.888 [0x6dce6450] DEBUG - Scaled up video bitrate to 23409Kbps based on 4.500000x fudge factor.
Jul 30, 2020 13:51:55.889 [0x6dce6450] DEBUG - Scaled up video bitrate to 23409Kbps based on 4.500000x fudge factor.
Jul 30, 2020 13:51:55.889 [0x6dce6450] DEBUG - Streaming Resource: Reducing playback quality for 685kbps stream bitrate: video resolution to 480x200, audio channels to 2, quality to 35, disable audio DS as 2147483647kbps is > the 153kbps available
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - Scaled up video bitrate to 23409Kbps based on 4.500000x fudge factor.
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - Scaled maximum bitrate for resolution reduction to 1463Kbps.
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - Clipped max bitrate to 526Kbps based on client-requested limit
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: Selected protocol hls; container: mkv
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: analyzing media item 230
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: The Banker (2020): Direct Play is disabled
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: The Banker (2020): media must be transcoded in order to use the hls protocol
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: The Banker (2020): selected subtitle cannot be converted to a compatible format, burning into video stream
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: The Banker (2020): avoiding video remux due to burned subtitle stream
Jul 30, 2020 13:51:55.890 [0x6dce6450] DEBUG - MDE: The Banker (2020): no remuxable profile found, so video stream will be transcoded
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations******
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - Scaled up video bitrate to 23409Kbps based on 4.500000x fudge factor.
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - Scaled maximum bitrate for resolution reduction to 1463Kbps.
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - Clipped max bitrate to 526Kbps based on client-requested limit
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - MDE: The Banker (2020): Audio Direct Streaming is disabled, so video's audio stream will be transcoded
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - MDE: Cannot direct stream audio stream due to profile or setting limitations*****
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - MDE: The Banker (2020): selected media 0 / 230
Jul 30, 2020 13:51:55.891 [0x6dce6450] DEBUG - Streaming Resource: Reached Decision id=117 codes=(General=2000,Neither direct play nor conversion is available. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=4002,Not enough CPU for conversion of this item.)*****
**Jul 30, 2020 13:51:55.891 [0x6dce6450] WARN - Failed to obtain a streaming resource for transcode of key /library/metadata/117****************THIS ISSUE**
Jul 30, 2020 13:51:55.892 [0x72423450] DEBUG - Completed: ------ipremoved----- 400 GET /video/:/transcode/universal/start.m3u8?advancedSubtitles=text&audioBoost=100&autoAdjustQuality=0&directPlay=0&directStream=1&directStreamAudio=1&fastSeek=1&hasMDE=1&location=cellular&maxVideoBitrate=720&mediaBufferSize=74944&mediaIndex=0&partIndex=0&path=%2Flibrary%2Fmetadata%2F117&peakBitrate=720&protocol=hls&session=--REMOVED---com-plexapp-android&subtitles=burn&subtitleSize=100&videoBitrate=720&videoQuality=60&videoResolution=3840x2160 (8 live) TLS 41ms 265 bytes (range: bytes=0-)
Jul 30, 2020 13:52:07.856 [0x72423450] DEBUG - WebSocket: client initiated close
Jul 30, 2020 13:52:07.856 [0x72423450] DEBUG - NotificationStream: Removing because of close
Jul 30, 2020 13:52:07.905 [0x72423450] DEBUG - handleStreamRead code 2: End of file
Jul 30, 2020 13:52:07.906 [0x72423450] DEBUG - Completed after connection close: -----IPREMOVED---- -3 GET /:/websockets/notifications (7 live) TLS GZIP 21921ms 10 bytes
I think the issue is related with this:
Thanks in advance
