"Failed to run packege service" - I tried many solutions but did not work
1.22.2.4276 install worked well for a day, decided to upgrade to 1.24.2.4973 using Plex’s supplied link to file PlexMediaServer-1.24.2.4973-2b1b51db9-armv7neon_DSM7
Same issue re-occurred. Uninstalled 1.24.2.4973, kept settings. Re-installed 1.22.2.4276 with existing installation. Back up and running.
Logs are below;
ep 15, 2021 09:35:54.307 [0x2e7bad48] INFO - Plex Media Server v1.24.2.4973-2b1b51db9 - Synology DS215j armv7l - build: linux-armv7neon synology-dsm7 - GMT 10:00
Sep 15, 2021 09:35:54.308 [0x2e7bad48] INFO - Linux version: DSM 7.0.41890-0, language: en-US
Sep 15, 2021 09:35:54.308 [0x2e7bad48] INFO - Processor Arm
Sep 15, 2021 09:35:54.308 [0x2e7bad48] INFO - Compiler is - Clang 11.0.1 (https://plex.tv e0c29d5827bc4eaaa2ceb882cbeed224b0960173)
Sep 15, 2021 09:35:54.308 [0x2e7bad48] INFO - /volume1/@appstore/PlexMediaServer/Plex Media Server
Sep 15, 2021 09:35:54.304 [0x2b5bfe90] DEBUG - BPQ: [Idle] → [Starting]
Sep 15, 2021 09:35:54.310 [0x2b5bfe90] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.35.5, threadsafe=1
Sep 15, 2021 09:35:54.361 [0x2b5bfe90] DEBUG - Running migrations. (EPG 0)
Sep 15, 2021 09:35:54.361 [0x2b5bfe90] ERROR - SQLITE3:(nil), 1, no such table: schema_migrations in “select version from schema_migrations order by version”
Sep 15, 2021 09:35:54.362 [0x2b5bfe90] ERROR - Database corruption: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version
Sep 15, 2021 09:35:54.362 [0x2b5bfe90] ERROR - Error: Unable to set up server: sqlite3_statement_backend::prepare: no such table: schema_migrations for SQL: select version from schema_migrations order by version (N4soci10soci_errorE)
@dandan81
Your logs show DB corruption, which will make the server stop.
Please confirm: Is it now up and running or still down ?
