Failed to Scan - TVButler Rasp Pi
Server Version#: Raspian ARMv7
Player Version#: 1.19.3.2843
Tuner Make/Model: TVButler
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Just wondering if folks are also failing out using a rasp pi v3 and TVButler. I had this working all well on my x86 plex machine but on the PI I am having a few issues.
Google led me to the rules files but that also did not work. Anything easy I can try or maybe just being a n00b.
cat Plex\ Tuner\ Service.log
May 23, 2020 17:02:05.865 [0x75e89450] INFO - Plex Tuner Service v1.0.0.0 - Raspbian GNU/Linux PC armv7l - build:
May 23, 2020 17:02:05.865 [0x75e89450] INFO - Linux version: 4.19.106-v7+ (#1297 SMP Tue Feb 25 13:10:07 GMT 2020), language: en-GB
May 23, 2020 17:02:05.866 [0x75e89450] INFO - Processor Arm
May 23, 2020 17:02:05.866 [0x75e89450] INFO - /usr/lib/plexmediaserver/Plex Tuner Service /usr/lib/plexmediaserver/Resources/Tuner/Private /usr/lib/plexmediaserver/Resources/Tuner/Shared 1.19.3.2843-e3c1f7bcd 32600 /waitmutex
May 23, 2020 17:02:05.863 [0x76025000] INFO - [I] broker_t::start...
May 23, 2020 17:02:05.871 [0x76025000] INFO - [I] device_manager_t::init.
May 23, 2020 17:02:05.871 [0x76025000] INFO - [I] device_manager_t::init. Initialize provider manager
May 23, 2020 17:02:05.871 [0x76025000] INFO - [I] device_manager_t::init. Initialize all device auxes
May 23, 2020 17:02:05.871 [0x76025000] INFO - [I] dvb_device_factory_t::get_aux_list
May 23, 2020 17:02:05.871 [0x76025000] INFO - [I] tvbutler_aux_t::init
May 23, 2020 17:02:05.878 [0x76025000] INFO - [I] web_server_t::start. Starting web server on port 32600
May 23, 2020 17:02:08.731 [0x74cfe450] INFO - [I] web_service_t::process_device_status
May 23, 2020 17:02:08.732 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx >>
May 23, 2020 17:02:08.738 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1624:512
May 23, 2020 17:02:08.738 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:33107
May 23, 2020 17:02:08.738 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:60416
May 23, 2020 17:02:08.738 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:10290
May 23, 2020 17:02:08.738 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8457:10259
May 23, 2020 17:02:08.738 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7449:256
May 23, 2020 17:02:08.739 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:38164
May 23, 2020 17:02:08.739 [0x74cfe450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
May 23, 2020 17:02:08.743 [0x744fd450] INFO - [I] web_service_t::process_device_status
May 23, 2020 17:02:08.744 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx >>
May 23, 2020 17:02:08.746 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1624:512
May 23, 2020 17:02:08.746 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:33107
May 23, 2020 17:02:08.746 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:60416
May 23, 2020 17:02:08.746 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:10290
May 23, 2020 17:02:08.746 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8457:10259
May 23, 2020 17:02:08.747 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8457:10259
May 23, 2020 17:02:08.747 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7449:256
May 23, 2020 17:02:08.747 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:38164
May 23, 2020 17:02:08.747 [0x744fd450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
May 23, 2020 17:02:08.751 [0x71cf8450] INFO - [I] web_service_t::process_get_scanners
May 23, 2020 17:02:08.751 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx >>
May 23, 2020 17:02:08.754 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1624:512
May 23, 2020 17:02:08.754 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:33107
May 23, 2020 17:02:08.754 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:60416
May 23, 2020 17:02:08.754 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:10290
May 23, 2020 17:02:08.754 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8457:10259
May 23, 2020 17:02:08.755 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8457:10259
May 23, 2020 17:02:08.755 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7449:256
May 23, 2020 17:02:08.755 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:38164
May 23, 2020 17:02:08.755 [0x71cf8450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
May 23, 2020 17:02:08.840 [0x724f9450] INFO - [I] web_service_t::process_get_channels
May 23, 2020 17:02:08.841 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx >>
May 23, 2020 17:02:08.845 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1624:512
May 23, 2020 17:02:08.845 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:33107
May 23, 2020 17:02:08.846 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:60416
May 23, 2020 17:02:08.846 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 3034:10290
May 23, 2020 17:02:08.846 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 8457:10259
May 23, 2020 17:02:08.846 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7449:256
May 23, 2020 17:02:08.846 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 1060:38164
May 23, 2020 17:02:08.846 [0x724f9450] INFO - [I] onetv_factory::DeviceGetListEx. Found device 7531:2
May 23, 2020 17:02:08.847 [0x724f9450] WARN - [E] web_service_t::process_get_channels. No tuner(s) in ds_channel_scan_finished state on device dvb#tvbutler#0#1:5
May 23, 2020 17:02:09.570 [0x70aff450] INFO - [I] onetv_factory. device_attached: 1:5, vendor 7449, product 256
May 23, 2020 17:02:09.571 [0x70aff450] INFO - [I] onetv_factory. device add request: 0x70101800```
Just noticed the log bomb out and starts again…
May 23, 2020 19:28:47.125 [0x6e6ff450] INFO - [I] onetv_factory::SetTuner. Tuning request. 474000, 8, 0
May 23, 2020 19:28:47.154 [0x6e6ff450] WARN - [E] Error. Received SIGSEGV: Segmentation Violation.
tail: 'Plex Tuner Service.log' has become inaccessible: No such file or directory
tail: 'Plex Tuner Service.log' has appeared;  following new file
May 23, 2020 19:28:47.302 [0x75dff450] INFO - Plex Tuner Service v1.0.0.0 - Raspbian GNU/Linux PC armv7l - build:
May 23, 2020 19:28:47.303 [0x75dff450] INFO - Linux version: 4.19.106-v7+ (#1297 SMP Tue Feb 25 13:10:07 GMT 2020), language: en-GB
May 23, 2020 19:28:47.304 [0x75dff450] INFO - Processor Arm
