TVButler 100TC error on scanning channels WARN - [E] Error. Received SIGSEGV: Segmentation Violation
Server Version#: 1.21.0.3711
Player Version#: N/A
Tuner Make/Model: TVButler
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
After trying TVButler on 3 differnet NAS (synology and QNAP), they all come abck with the same error (where TVMosaic works jsut fine).
WARN - [E] Error. Received SIGSEGV: Segmentation Violation.
Plex recognises the tuner in DVR setup screen- and you can get as far as ‘scann channels’ - it sites at 0% for about 10 seconds, and then says no signal and to check antenna.
Logs are as follows (from QNAP and Synology)
QNAP:- (File removed)
SYNOLOGY:- (File removed)
I have tried uninstalling Plex on both platforms, and reinstalling - but no change.
I have exactly the same problem
Other solutions are to remove completely TVMosaic
What I did but no solution
