Failing to Tune Live TV
Server Version#: 1.21.3.4021
Player Version#: Plex Web Version 4.51.1
Tuner Make/Model: HDHR5-4US
Guide/Lineup name: using the OoTB Guide
Using XMLTV?:
Channel number/Name: 7.02 WSVN
I can open the channel with no issue in the HDHomerun desktop app.
I deleted and readded the tuner, same issue
Feb 16, 2021 15:11:14.364 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] Unable to find title for item of type 5
Feb 16, 2021 15:11:14.365 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] Unable to find title for item of type 5
Feb 16, 2021 15:11:14.728 [5772] Error — [Transcoder] [mpeg2video @ 0272b100] Invalid frame dimensions 0x0.
Feb 16, 2021 15:11:14.737 [5772] Error — [Transcoder] [mpeg2video @ 0272b100] Invalid frame dimensions 0x0.
Feb 16, 2021 15:11:14.798 [5772] Error — [Transcoder] [mpeg2video @ 0272b100] Invalid frame dimensions 0x0.
Feb 16, 2021 15:11:15.017 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] Unknown metadata type:
Feb 16, 2021 15:11:15.018 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] SQLITE3:0xaa3529d7, 14, os_win.c:45632: (87) winOpen(C:\Users\ADMINI~1\AppData\Local\Temp\2\etilqs_82ht62bKaQLcY9S) - The parameter is incorrect.
Feb 16, 2021 15:11:15.018 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] SQLITE3:0xaa3529d7, 14, cannot open file at line 45633 of [bf8c1b2b7a]
Feb 16, 2021 15:11:15.018 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] SQLITE3:0xaa3529d7, 14, statement aborts at 160: [insert into metadata_items (library_section_id,parent_id,metadata_type,guid,hash,media_item_count,title,title_sort,original_title,studio,rating,audience_rating,rating_count,tagline,su
Feb 16, 2021 15:11:15.018 [4764] Error — [Grabber/007-muvk2a3bx35iaqip6r1ptjfh] Exception inside transaction (inside=1) (…\Library\MetadataItem.cpp:1142): sqlite3_statement_backend::loadOne: unable to open database file
Feb 16, 2021 15:11:15.018 [4764] Error — Thread: Uncaught exception running async task which was spawned by thread 5116: sqlite3_statement_backend::loadOne: unable to open database file
Feb 16, 2021 15:11:15.020 [1832] Error — Error issuing curl_easy_perform(handle): 6
@Firespyer Do you have Roku and android clients? I am seeing similar things in my logs.
I do, none of them can view Live tv
So it must be the server if you’re not using those to tune live TV. I thought it was the Android device causing that error:(
