[FEATURE REQUEST] A-Z Television Library
Is it possible to add the A-Z bookmarks like in the movie library on the television library page?
I actually have more TV series than I do movies - but it’s harder to navigate without these handy bookmarks/navigation crumbs
it’s on the right side of the screen just like movies. not sure which player app you are using though.
In the web app - small poster size - if you have less than 100 items you get no list:
If you raise the poster size one click the list pops in:
For libraries with substantially less than 100 items you may have to raise the poster size several clicks to get a list, or you may not get it at all, depending on how many you have and this is Plex arbitrarily deciding if you need a list or not.
I get that list coming and going all the time in the apps - where there is no poster size adjustment, so it’s down to Plex deciding for me - because I certainly wouldn’t know what to do with a decision like that and would obviously make the wrong choice.
hmm… I can confirm that there’s no A-Z index showing for libraries below a certain # of items (could be the “100” mentioned by Tony) – this is not specific to a particular library type. I can repeat this also with movies when filtering my library to a small number of items.
However the index won’t show up for if I change the raster size.
It’s very mysterious… but I’m certain Plex is making the right choice for me - 'cause I’m way too stooopit to make those kind of decisions… I should concentrate on:
Should I step in front of that Bus?
I wonder what will happen if I try to breathe underwater?
Should I stick my junk in that light socket?
You know, the important stuff…
B)
Not really. It’s just a bug, not a conspiracy. It might be browser related as i have libraries with less than 100 and it does show for me on smallest.
I’m using Chrome. It’s pretty popular by all indications.
As previously mentioned - this also happens in the Plex Apps (Roku/AFTV particularly) - with random disappearance of the index - and when you’re stuck in the Twin Horizontal Scrolling Mambo - with no index - you’re having a bad day and considering self emulation.
I’m using chrome as well and working fine here. Anyway, I’ll make a bug report.
@Batmanfan67 does it appear for you if you change the size of posters?
