Alpha Listing Scrollbar missing on library view of second TV Library
Server Version#: 1.24.3.5033
Player Version#: 1.35.1.2632-c6783c78
I have 2 TV libraries, one for HD and one for UHD. When I go to the library listing of the UHD TV library, the alphabetic listing with the scroll bar is missing on the right hand side. If I go to the HD library listing, the alpha listing with the scroll bar appears.
This is the same if I access the library directly from the server (localhost:xxxxx/web/…) or if I access it from my laptop via browser or via plex windows player or a TV
I have two movie libraries (HD and 4K) and they are both working correctly.
I also see there is a listing in the forms for the same issue with the linux version of the server (Jul 23).
How many movies TV shows in the library?
It is not movies, it is TV shows. In the UHD there are 70 series, in the HD there are 68 series.
The home screen is set to All / TV Shows / By Title
Hmm, I don’t know, then. I think the library size rule applies to all library types, but I can’t explain why your smaller library has it and the larger one doesn’t.
Check for a damaged database. There might be an index table damaged.
