[Feature Request] Add unwatched counter to On Deck (Where unwatched > 1)
In some areas (show/episodes view) you see a yellow counter in the top corner with the number of unwatched episodes.
In the On-Deck area, you see a triangle in the corner to show that the specific episode is unwatched.
If there are shows which are displayed On-Deck that you are a few episodes behind, it would be good to change the triangle to a counter. This will help prompt you to catch up on the shows where you’re more than a week behind.
I have wanted this feature for ages
It’s on “recently added television” so I see no reason why it cant be added to “On Deck”.
Same screen - one row down.
2022 clean-up: duplicate (while the other thread is newer and has also no votes, it’s focusing on features available today; e.g. reflecting there’s no more On Deck section)
