Feature request - adjust audio offset
Hi - I have been a longtime user of Plex, and fell in love with Plexconnect. A wonderful masterpiece! I had been a old user of XBMC (on the original XBox, remember that thing?)
One thing that I wish that could be incorporated would be an audio offset setting. Sometimes, I have some files that do not play fully in sync, and would need a slight audio offset tweak. Could that ever be incorporated in PlexConnect?
Thanks for everything!
I will add it to roadmap discussions.
Hi
Any progress on this? I've been noticing that some of my movies an series are out of sync when using plexconnect. Especially if I resume a movie.
No progress as of yet.
What happens if you use the iOS client (it is more likely to be a PMS bug than a PlexConnect I’ve but this would help narrow it)?
I think it's a PMS thing. Have the same "issue".. I just adjusted the time on my AV reveicer....
It's the same on ios and webplayer on the files I had problems with.
Some older movies can I live with but on recent movies it's a bit frustrating.
It would be nice to have the ability to ajust the sync directly in plexconnt. I don't have a home theater system where I can do the changes.
Is it possible to implement it?
You should be making the adjustment on your AV receiver by the looks of it.
...he doesn't seem to have the chance to adapt this on his audio equipment.
Question - is the aTV/iOS set up for such a delay option? Always remember... once we hand the movie over to aTV there is no PlexConnect involvement any more. It's all handled between aTV and PMS.
dont forget to turn off any post processing settings on your tv (ie turn on 'game mode' on your tv).
No, I don't have any audio equipment connected to my tv. And the Tv is a 3 year old Sony that doesn't have much audio settings.
I see the problem with the handling between plexconnect an atv. Mayby its possible to add the feature to the play-menu? Or even in the plex web interface.
The problem is that I only use Plex on my ios devices and atv. I scrapped the htpc a few years ago and go a Boxee box but when plexconnect was released I scrapped that one to.
Nice...
As you indicate it is not a "bug" of PlexConnect, but a somewhat bigger issue with iOS in general... did you try to discuss this in the PMS forum? Are the movies in question direct played (m4v) or transcoded (mkv, avi, ...)?
I'll try the PMS general forum instead.
I just thought that it would be a nice feature to plexconnect to be able to ajust audio sync problem directly through the atv. Like on the boxee box.
The Boxee box was really nice in some prespectives but the solution with plex, plexconnect and ios is unbeatable. But I can't help miss some of the functions from the box such as audio sync and subtitle search.
But whos knows, maybe some day Apple will realise that they should add an appstore to the atv. Then life would be sweet :)
You might want to check out the open subtitles agent (not sure how good it is).
Hi - I have been a longtime user of Plex, and fell in love with Plexconnect. A wonderful masterpiece! I had been a old user of XBMC (on the original XBox, remember that thing?) One thing that I wish that could be incorporated would be an audio offset setting. Sometimes, I have some files that do not play fully in sync, and would need a slight audio offset tweak. Could that ever be incorporated in PlexConnect? Thanks for everything!
+1
