[Feature Request] Circular browsing flow for Plex Media Player menu items
Apologies in advance if this turns out to be requested before; I couldn’t find something similar on the forum.
When going through the main top level menu of Plex Media Player by keyboard (Home, Movies, Shows, Music, Photos, Videos and News but also the personal drop-down with Settings, Switch User, Media Server Status, Sign Out and Exit) I find myself having to hit the Right arrow key 7 times followed by Enter and 4 times the Down arrow key to go from Home to Exit to actually exit Plex. This is not very user friendly and could be sped up significantly by allowing the user to press the Left arrow key (A), Enter and finally one Up arrow key (B) to reach Exit in the personal drop-down. In effect creating a circular browsing flow. See the below illustration:
The pressing Enter to go in to the personal drop-down could also be avoided by allowing pressing Up or Down to go in to the drop-down menu, thereby ending up on Settings and Exit respectively.
My description is for Plex Media Player with a keyboard but I’m sure this would also be useful in other client players with either keyboard or remote.
Does your remote have a ‘Back’ button?
Try it while at the home page.
If using the keyboard I believe it is backspace that will bring you to the exit screen when on the home screen.
Ah, I see. I’m currently using the keyboard for my Mac and the backspace tip is golden. Thanks SiscoPlex!
I still think the circular browsing flow is a natural way to approach menus. The backspace/back button are a nice shortcut but the standard flow should also be as convenient and intuitive as possible IMHO. Any thoughts on this?
