[Feature request] Home button in full player screen (Plexamp)
Simple but useful, I would like to see a home button on the full player screen.
The home screen is my main interaction screen, and when playing music I use the full player screen. It seems logical (to me) to always have the home screen one click away.
If you started playback from the Home screen, it is right behind the player.
All you need to do is to minimize the player.
On touchscreens you swipe downwards. With a mouse you click on the downwards chevron at the bottom.
Thanks for your reply!
The minimizing of the player is exactly the step that I would like to skip, because often there is a library screen behind the player, which means another tap/click back to the home screen.
There is enough room for a (optional) home button in the same row as the minimizing button.
