Feature Request - Multi Episode Tagging
Hi all,
I thought I’d post an enhancement request that would make plex an even more wonderful environment than it already is.
Just say you have a file which is some.show.s01.e01-e05.mkv (if following plex naming conventions). The current behaviour would be that plex would create 5 episodes with all correct metadata but all pointing to the same file on disk.
New improved behaviour:
Allow for each episode in a single file set allow the definition of a start time for that episode segment within its metadata. Of course this metadata should never be overwritten by any library update process.
What do you guys think?
Cheers,
David
Early 2021 clean-up: duplicate (while this post is older, it appears to have been abandoned / no votes while the newer one is more active)
