Feature Request: Offline playlist creation
Hi, I have a feature request for Plexamp based on an experience I had earlier. I was out, listening to a mix I had generated, and I wanted to save some songs I liked to a new playlist, for reference when I’m back home. But for some reason Plexamp had decided that it can’t connect to my server, even though I had internet and the Plex app worked. Anyway: No connection, no playlist creation.
I think it would be nice to be able to create playlists from the downloaded songs you have, even while you’re offline, which are then synchronized to the Plex server when you’re back online. This would improve the offline experience, because you’re not limited to only listening to your downloads as they are, and when you have internet again you’ll also have those playlists everywhere else.
thanks for the suggestion! as you point out, at the moment at least, playlists are a purely server-side artifact so we can’t create them while offline.
